HELP: My ATI Supredamper has hex head cap bolts on it. Clear the PS rack (C5)???
UPDATE: Just in case anyone find this thread searching out answers to the same issue here's an update. I sent the balancer assembly back to ATI to be modified at a cost of $40 + shipping. They machined the balancer face to accept the proper flush hardware and chamfered a 45 degree edge in the hub snout so the backside of the hardware wouldn't hit. I got it back together and installed all w/o issue. I'm glad I went this route, vs. trying to find shallower bolts, because there still isn't a ton of clearance between the balancer and steering rack. The front edge of the ATI is a good bit thicker than the OEM one so it needs all the room it can get.
**All newer y-body balancers come with flush hardware allready. I just happened to buy one from ThunderRacing that had been sitting on the shelf since 2007 so it was an older design.
Installed a y-body 10% underdrive unit w/o AC for my racecar build.... the balancer has hex headed bolts in the end that look like theyll be very very close to the PS rack.
Anyone run a ATI w/ these bolts? Can you get the rack back in w/o issue?
I had a 10% unit w/ AC on my old yellow Targa Z and it didnt come w/ these bolts that stick out.... they were all flush to the balancer end.
Thoughts?
Thoughts?
TTT.... ATI is saying that all Corvette balancers come with flush hardware. The box specifically says y-body on it.
Anyone?
Anyone?
Well I researched and answered my own question... the balancer I purchased from Thunder Racing is an older design where the bolt-heads are very very close to the steering rack and on hard braking will hit it.
Rick @ ATI was more helpful once I had the PN and everything and verified that Thunder ordered 2 units of the PN's that I have back in June 2007. Currently all Y-body balancers have all counter-sunk hardware.
So my options are to pull the balancer off and send it to them to be modified to newer standards or go find a low-profile bolt that will work.
He said some people will just run them w/ the 3 botls out, but it is not what you're supposed to do.
I decided to do it the 100% right way to get the most clearance and send it back to ATI. Unfortunately I got a call today that I have to send the hub as well and they neglected to tell me that. It's edge has to be chamfered a little to clear the head of the new counter-sunk bolts.
