Mr. Gasket Thermostat
Got the Mr Gasket 160 stat. How are you supposed to use this? It is not like the stock 1 piece thermostat housing, it is just a thermostat. To get it to fit I had to snap the stock aluminum bridge and t stat outta the stock housing and use silicone when I installed the Mr. Gasket one.
Any reason why this wouldn't work, anyone tried it?
V6 is correct, the Mr. Gastket one is incorrect. Return it and have a read here: https://ls1tech.com/forums/13344643-post9.html
in the old style water pump they do as does kragen (o-Reilly) and napa. when the water pumps where redesigned by GM with a new back plate they got a different t-stat housing that fits both water pumps but the old t-stat housing will not fit the new water pump design . . . ask me how i know lol
Why would you buy a new water pump just so you can use that thermostat you bought? Just get the thermostat that Paul posted the link for.
Here I'll help you out: Auto Zone part# 15296
I've had the car on the dyno the last couple of days and no coolant leaks and it seems to operate like a 160 should, so I'd say if you want to pay $9 for the mr gasket one its cheaper than the autozone one if you don't mind modding the t stat hosing a little.
