No oil pressure
Old 08-10-2010, 03:43 PM
Esco99's Avatar
Default No oil pressure
I just did a LS6 intake swap on my 98Formula and now I have no oil pressure what could of I had done wrong?
Old 08-10-2010, 04:08 PM
2001NBMZ28's Avatar
Forgot to connect the sensor to the harness, or broke it doing the intake? It was OK before the swap right?
Old 08-10-2010, 04:10 PM
Esco99's Avatar
ya it was fine before........ can you show me a pic of the sensor that your talking about
Old 08-10-2010, 04:14 PM
2001NBMZ28's Avatar
Probably a pic here somewhere - but it's the vertical cylinderical black sensor behind the intake, on the drivers side.
Old 08-10-2010, 04:18 PM
Esco99's Avatar
The one attached to the Intake?
Old 08-10-2010, 04:25 PM
2001NBMZ28's Avatar
No, it screws into the rear deck.
Old 08-10-2010, 04:35 PM
2001NBMZ28's Avatar
You can see it in this pic with the intake removed: http://www.ls1howto.com/geniii/howto...//image015.jpg
Old 08-10-2010, 04:39 PM
Esco99's Avatar
I never touched that....maybe my vacuum line hit it or something.
Old 08-10-2010, 04:49 PM
conor.davis's Avatar
OPSU broke. is it leaking oil when running?
Old 08-10-2010, 04:52 PM
01wssick's Avatar
Oil pressure sending unit prolly broke off, ver easy to break. costy mistake lol.
Old 08-10-2010, 05:59 PM
Esco99's Avatar
no its not leaking oil. i'll fix it tomarrow
Old 08-11-2010, 05:32 PM
11SECSS's Avatar
It was the oil press unit that was broken.
Old 08-11-2010, 07:43 PM
Moose67's Avatar
Thats your problem. My son just finished taking the intake back off cause of the same problem. Did an LS6 intake swap yesterday, started it up and no pressure. Sure makes your butt pucker.
Old 08-11-2010, 09:17 PM
Esco99's Avatar
Ya I turn her off fast when I saw that happen.
