Electric Fan temp switch.
Old 08-11-2010, 02:50 PM
meinthe73's Avatar
Default Electric Fan temp switch.
Can someone please inform on the water temp on which a 2001 ls1 Camaro SS will the fans turn on? thanks
Old 08-11-2010, 03:16 PM
Old Geezer's Avatar
Default That's in
the PCM settings.
Old 08-11-2010, 03:59 PM
2001NBMZ28's Avatar
Both fans low speed on 226, off 217. Both fans high on 233, off 226. Numbers are stock PCM setting for a 2K. If you need the exact '01 numbers I can look them up in my helms.
Old 08-11-2010, 06:45 PM
meinthe73's Avatar
Thank you exactly what I needed to know. I doubt the 01 would be different, but I you want to find out then relay that info to me it would be greatly appreciated.
Old 08-11-2010, 07:38 PM
2001NBMZ28's Avatar
Looked it up, pretty close. Low speed on 226, high speed on 234. Also depends on if the AC is called for of course, according to ambient temps/pressures. Also at key off if the temp is 284 or above, fans will continue runing for a couple minutes - overheating.
Old 08-11-2010, 10:25 PM
meinthe73's Avatar
Looked it up, pretty close. Low speed on 226, high speed on 234. Also depends on if the AC is called for of course, according to ambient temps/pressures. Also at key off if the temp is 284 or above, fans will continue running for a couple minutes - overheating.
Thanks, Reason I was asking is because I swap an 2001 Ls1 into my 73 Vette and I ran the motor yesterday for 10 minutes or so but the fans did not turn on so maybe it did not get that hot just idling.
