2000 C5 Corvette supporting mods the same as F-Bodys 4 Cam swap?
Old 10-27-2010, 08:12 PM
1999FirehawkLS1's Avatar
Default 2000 C5 Corvette supporting mods the same as F-Bodys 4 Cam swap?
Got a 2000 C5 T56 vette coming to do a cam swap in.......
What are stock injector size on these cars?
Will fuel Pump need to be upgraded?
Guessing stock clutch is to be pronouced DEAD! after this just like the F-Bodies lol
Old 10-28-2010, 03:57 AM
Beasst8's Avatar
Injectors are like 28lbs from the factory.
I upped to 36Lbs with my cam swap. No fuel pump should not have to be.
Im easy on my car. I still have the Factory Clutch and it doesnt slip. YET.
Old 10-28-2010, 10:59 AM
lol thx what cam did u choose to run w?
Old 10-29-2010, 03:11 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
The 2000 cars had 26lb injectors from the factory. Typically on a cam only setup you can stick with the stock injectors and fuel pump and still be alright. Once you add heads usually the injectors will need and upgrade.
Old 11-03-2010, 05:04 PM
awsome thx thing this guys got the TSP 228r cam
Old 11-03-2010, 06:31 PM
bczee's Avatar
Most likely you should be ok, but get a scanner and monitor the injector duty cycle percentage one it is up and running.. but would hurt to step up the inject size a few #'s !
Old 11-03-2010, 08:09 PM
Ya i wish he would but he wil do like the rest and find out the hard way and go to tune it and cant and wast his tune guys time lol seen this happen alot!
Old 11-03-2010, 08:10 PM
Was wondering how much WHP the FAST 36lbs injectors will hold up to on NA cars?
