Is fast lower shell part# 54006 discontinue??
My lower shell cracked and I placed an order at rpm outlet I called them today to check if they shipped the lower shell and was told that is no longer available i call another store and was told the same thing Do you guys know where can I get a lower shell or is it time to upgrade to a 102mm
I tried Jb weld and dint work it holds for a few minutes and cracks again I have tried with other welds and same thing happens!! today I called 3 other stores and was told the same thing I guess if you can buy replacement parts the fast intakes 76mm 90mm & 92mm are junk now!!
if you can find out what type of plastic it is.....you can get a specific plastic epoxy....different plastics need different epoxies there is no one size fits all......JB is not a cure all...ask me how i know.....harbor freight does sell a plastic welder....but i have never used 1
I think Comp Cams bought Fast Performance because I was told from one of the stores that I called that they order the lower shell directly from manufacture comp cams and they were told that is no longer available and to -- sjsingle1 -- thanks for the website I will call them on Monday and will try welding the intake one more time!!!! I was thinking can it be repair with fiberglass I now a place where they repair boats they probably can do something!!??
