What to do with downstream O2 sensors LT install
Ok bought a used set of Pacesetter LTs with catted y pipe for my 2000 WS6. The headers have the bungs for the O2 sensor the y pipe doesn't. What do I do with my stock downstream sensors? Do they unplug or is there other majic to delete them? Help I have the exhaust removed to the cats and the bolts are loose, would like to know before I take the cats off. Thanks
LS1Tech Premium Sponsor
You'll want a good tune anyway, so I'd save the money on simulators (assuming you can find them in good shape) and spend that $$ on the tune which will delete the codes for the rear O2's!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I believe the Secondary O2's simply do a double-check to make sure the Cat's are working.
The Simulator's are rarely sold 'new' anymore because of regulations.
You can occassonally find them as 'used' parts for sale in the forums, & sometimes even Ebay.
The best thing to do, find a local speed shop who can 'tune them out' & go that way.
Sim's will cost you at least $50-100+.
Tune may be $200-400 depending on how far you go with it.
Heck, some shops will do the Secondary-O2 tune-out for a few bucks & walk away.
#1) Find a local shop.
And always read the stickies:
https://ls1tech.com/forums/generatio...mount-faq.html
