ebay catch can(vms racing)
Old 03-18-2011, 02:12 PM
69cutlassrkt's Avatar
Default ebay catch can(vms racing)
I have a few questions about it.
Is it hooked up right?
And can I put the oil it collects back in the motor?
I have one hose coming from the valve cover going to it and the other one from the intake manifold behind the tb.
Old 03-19-2011, 02:26 AM
SoWazIt2You's Avatar
Not sure about routing i will leave that up to someone else. https://ls1tech.com/forums/generatio...outing-ok.html
I would not out the oil back in the motor, most of people have a mixture of oil and water, so yea not a good thing to put back in.
Let me know how that one works out for you im looking for a decent, not expensive catch can myself and would like to see how this one works out. Any chance i can get some pics of the can open? What type of filtration system does it use?
Old 03-19-2011, 04:34 AM
Steve Gunn's Avatar
Can't see your PCV valve?
Old 03-19-2011, 10:16 AM
Rare96LT1Formula's Avatar
I've seen these online...curious how well they work. Any oil/water in the can yet??
Old 03-19-2011, 10:39 AM
Don't have one. It is already collecting oil. The oil in my intake was getting on my map sensor and messing it up, hopefully the catch can will fix that.
Old 03-19-2011, 10:47 AM
Thanks. I looked at that thread and I think I have it right, just wanted to make sure. The can doesnt open and I think it doesn't have a filtration system.
Old 03-19-2011, 04:09 PM
Steve Gunn's Avatar
You need a valve. PCV stands for positive crankcase ventilation. You want to evacuate the crankcase... one way. Read up some more. It's important.
Old 03-20-2011, 10:31 AM
I'm gonna eventually get a breather for crankcase ventilation, the one that goes where the oil filler tube is. http://www.pfyc.com/pc/GN3020/GNUNDE...er+Filter.html
http://rpmspeed.com/product_info.php...ts_id=23441353
Old 04-03-2011, 04:42 PM
Just put on the valve cover breather. It sits up really high with the truck oil filler tube, but it still fits. And I replaced the catch can lines with rubber hoses cause the one coming from the valve cover sort of collapsed.
Quick Reply: ebay catch can(vms racing)
