Need a coupler tube for the 104mm lid to a 90mm TB
Old 03-26-2011, 10:27 PM
The Dragon's Avatar
Question Need a coupler tube for the 104mm lid to a 90mm TB
I'll have no MAF. Lid straight to the TB.
A 4" coupler fits over the FAST TB but that would be 3/8" too small for the lid.
Where do you guys get these couplers because I couldn't find anything matching these specs or even CLOSE to long enough in the Plumbing Department of Home Depot???
Old 03-26-2011, 11:17 PM
RARON455's Avatar
Look on siliconecouplers.com I actually got mine off ebay, and dont worry about that 3/8 the silicone will stretch with a little persuasion.
Old 03-27-2011, 04:07 AM
The Dragon's Avatar
Lightbulb
Just drilled a 5/8" hole with a Diamond Tile drill bit.
Attached Thumbnails Need a coupler tube for the 104mm lid to a 90mm TB-photo-2-.jpg   Need a coupler tube for the 104mm lid to a 90mm TB-photo-3-.jpg
Old 03-27-2011, 07:57 AM
zracer323's Avatar
Just ordered mine from intakehoses.com. I had the same concern as you (except I have the 98mm lid). I bought a 4"ID x 6" long. If you aren't in a hurry I can measure the inlet and see if it will fit over the 104mm lid. I should have it sometime next week.
Old 04-20-2011, 03:02 PM
The Dragon's Avatar
I tried to stretch that 4" hose over the lid for over half an hour with no success.
I emailed the hose company to see if they can send me one that fits a 4 1/4" or 4 3/8" outer diameter.
This S U C K S
Old 04-20-2011, 03:05 PM
dutinsss's Avatar
try setting it in the oven for a little bit. it'll make it more pliable.
Old 04-20-2011, 03:47 PM
The Dragon's Avatar
I tried microwaving it already. I'll give the oven a try.
Old 04-20-2011, 05:45 PM
The Dragon's Avatar
Man I put that thing in the oven on 200* for almost 10 minutes- tried needle nose pliers and a flat head screw driver with no go.
Do I have to cook this thing like a turkey or what?
Old 04-22-2011, 10:27 PM
dutinsss's Avatar
i guess if it felt like it could get a little hotter without melting, you could put a little more heat to it. then put a little grease on the ends. if that doesn't work, it's just too small.
Old 04-22-2011, 10:49 PM
garygnu's Avatar
get a bigger tube and use as a coupler with silicon.
Old 04-23-2011, 09:01 PM
The Dragon's Avatar
Lightbulb
Already ordered last week. Should be here Monday.
I'll just wrap around the throttle body if necessary.
Old 07-25-2013, 12:05 AM
Firebirdmuscle's Avatar
What coupler did you end up getting?
Old 07-25-2013, 02:58 AM
carolhqx's Avatar
Old 07-25-2013, 05:22 PM
The Dragon's Avatar
Lol I ordered from a site online but canceled when I picked up the longest plumbing tube Home Depot had; perfect diameter and barely long enough but it fits.
Old 07-25-2013, 05:27 PM
Is it a fernco? What's the part number? No one makes what I'm wanting.
Old 07-25-2013, 05:40 PM
The Dragon's Avatar
Baker's Tube.
Old 07-25-2013, 08:00 PM
Pic of it
Old 07-25-2013, 08:03 PM
Are y'all dremeling out a little of the plastic on the lower air box beneath the neck of the airlid to make these work?
Old 07-25-2013, 08:22 PM
M.BOZZ's Avatar
Default coupler
I have a 104mm lid and used a 4 inch coupler, I used a DA ( on the coupler ) and keep grinding away until it would slip on with a little lube. And yes you have to take alittle of the radiator support right bellow the coupler. I bought the coupler from Vibrant Performance
Old 07-26-2013, 09:20 PM
The Dragon's Avatar
Lightbulb
Didn't dremel anything.
Quick Reply: Need a coupler tube for the 104mm lid to a 90mm TB
