What is the best intake setup?
I got a 408 i was looking to upgrade the intake on from a LS6 to something bigger, anyone have any luck with Fast LSX intake or Vic jr set up?
If you're running a wide overlap cam, you can run a Vic Jr. FWIH, they're not good for smaller cams with smaller overlaps.
If it's a mile to medium cam, a Fast intake should fit the build nicely. There really is no "best," inly what will work with your setup.
I got a 238 241 .600 lift cam on a 114 lsa ran a plan jane ls6 intake with stock tb and stock maf and the car was decently fast for what it had but i could tell it was struggling for air
Captain Double Post
ok if someone could clear this up for me that would be great,I was told by a few people that the vic jr, would be great for my setup,ms4 stage 1 243s,others told me to stay away from it,the info that I got that I would lose torque and low end,and only gain a lil bit up top,as where a fast intake i would not take a loss anywhere and gain across the rpm range,figure this is a good question for this thread,I don't know much about other intakes outside the fast and ls6,but the vic jr looks bad ***,that's about all I know about it,this is on a ls1 by the way
#1 Elbow fitment. 90 degree low pro elbows hurt flow a good deal. You will need at least an SS hood maybe even a bigger cowl style hood to fir a full size 90 degree elbow.
#2 Make sure you port the intake to match the heads, they are in dire need of it in most cases.
On the plus side, they are usually more likely to survive a nitrous backfire. They also look pretty mean.
Are you an A4 or M6? Stall/Gear info?
