Does anybody know which oil pans have the dipstick mounted in the pan instead of i the block? My swap requires a dipstick in the pan, and I can't find many that fit that criteria. Help? Thanks!
Trailblazer SS pan does. The pan is a front sump, I have a complete set up ready to go....Pan, Pickup tube, Windage tray and yes you quessed it, Dip stick.
how about blocking the hole in the block, and drilling and welding a fitting to any pan you want? then just cut the dipstick tube accordingly to the length you need(put the fittign an inch lower, cut the tube up top by an inch.
I have no hole in the block - thats the point. I need a pan that has a dipstick tube integrated. I'm not sure I want to custom-build that, oil level's pretty important and the factory measured well. I'm not very good at fab to trust myself to do that.
