4 barrel fast tb on ls1
Old 07-03-2011, 10:36 PM
Evilution's Avatar
Default 4 barrel fast tb on ls1
i have the fast 1375 cfm 4150 tb and the victor jr. intake. what throttle bracket do i use? also so i need a new throttle cable? any other odds and ends i may need for the install? just wanna make sure i have all the parts needed. and yes i will be getting a SD tune.
tb part number is FAST 307603
Old 07-04-2011, 12:05 PM
98SSClone's Avatar
The 86-93 S10 4.3 TBI throttle cable should work... not sure about the bracket.
Old 07-04-2011, 03:20 PM
BADD SS's Avatar
I ordered a regular anodized aluminium one for a carb that was red, and modified it for the stock cable. Dont get a lokar cable whatever you do, they friggen suck.
Old 07-04-2011, 11:25 PM
nastychevelle's Avatar
i used a regular carb style bracket with a 89 blazer throttle cable on my Accell 4150 TB setup.
Kind of a bad picture (wasnt finished with everything)
Old 07-05-2011, 03:59 PM
Dmoney's Avatar
This is what I ordered:
Part #
29086 Vic Jr. w/ fuel rails
TC1000636 Lokar cable(cut to fit)
15152 Jegs throttle cable bracket
M592438 intake gaskets for Vic jr.
RGR501 fuel rail kit from Speed Inc.
9749 (2) 45* elbows
9849 Spectre carb hat
Take your Map sensor off you intake and the Victor Jr. will come with a bracket to mount the MAP sensor to the back bolt on top of the intake before you bolt on the throttle body and you just run a hose from the sensor to the intake...........
Old 07-17-2011, 12:23 PM
subhumanzz's Avatar
4.3l blazer cable?
Old 06-29-2015, 10:03 AM
Mike Blanco's Avatar
I need to get a pedal and Throttle cable for this super vic setup. I was planning on getting a Lokar pedal and their throttle cable. However, not sure if I will now. I spoke to them this morning and they did not have a brake for the cable mounting to the motor. Any ideas on a pedal and cable recommendation?
Old 06-29-2015, 11:32 AM
slowsol95's Avatar
Im using a regular oem throttle cable and using a lokar cable end to adapt it to the 4150 throttle body. This was the cheapest option if you already have the correct gen gm cable.
Old 06-29-2015, 09:06 PM
Right now I do not have anything. I need a pedel, cable, and I think there is some bracket that I need that will bolt to the motor. Also my throttle arm on the 4150 is striking the underside of the air filter. I guess once I get it outfitted I can just cut the top of the arm on the 4150 to clear the air filter?
I am just trying to figure out how I need to set this up and the parts I need. This is my first setup. All help is appreciated.
Quick Reply: 4 barrel fast tb on ls1
