Homeless connectors!
Have two connectors under my dash that seem to have nowhere to go. Any ideas? It's been apart for a year and I can't remember what they were for.
could be something your car didn't come with? i had to unbolt my PCM a few months back to run some wires for the auto trix kit and after i put the pcm back i found a gray wire with a plug on the end of it and couldn't figure out what it was for or where it came unplugged from. i googled it and it was a connector for the clutch safety switch. well, since my car is an automatic, that explains why it wasn't plugged in GM is known for using the same wire harness regardless of whether or not the car has an option on that harness or not.
94/2000 hybrid
My sig was several (10) years old, will update later
I just want to make sure everything is connected properly before I try to fire her for the first time. There will be enough other issues that I don't want to with the damn wiring.
That's MISTER MODERATOR
The blue 8 way plug appears to be for the daytime running lights and goes into the headlamp auto control.
The only 10 way natural plug I can see is at the right hand hinge pillar and is listed as "to engine harness" but your picture shows it pretty far away from the right hand hinge pillar.
