Oil Consumption
Old Aug 5, 2011 | 03:26 PM
91lxstang's Avatar
Default Oil Consumption
I have had my car for about 3 weeks now and I have put about 2000 miles on it.
In the past 1500 miles or so I noticed it was losing about 1 quart of oil. I dont think its burning it as I have never seen it smoke or anything. Do you guys think I just need a catch can? It isn't leaking either.
I'm gonna pull the TB and see if there is any oil behind it sometime today.
Any ideas?
Old Aug 5, 2011 | 08:45 PM
91lxstang's Avatar
any ideas?
Old Aug 5, 2011 | 09:04 PM
mean_greenZ's Avatar
There are thousands of threads about this. It's "normal" for these engines b/c of our crappy pcv setup.
Mine does it. I honestly think mine likes being 1/2 qt. low. I can add to it and it drops back down to 1/2 low on the dipstick and doesn't budge.
Old Aug 6, 2011 | 04:13 PM
LS1121's Avatar
Not True, mine doesn't do it.
Old Aug 6, 2011 | 05:08 PM
PheonixLS1's Avatar
It actually IS true!! Go to ANY chevy or pontiac dealer and they have a whole write up straight from the manufacturer that says its absolutely normal for ALL late model GM motors to consume about 1 quart of oil every 2000-3000 miles. If yours doesn't do it, great, but just because YOUR motor doesn't do it doesn't mean its not fact.
Old Aug 6, 2011 | 05:15 PM
LS1121's Avatar
Sorry ..... installed an in line oil filter between my PCV valve and the intake, 3000 miles and I have about a tablespoon of oil in the bowl. Sorry but you guy's have other problems.
Old Aug 6, 2011 | 05:26 PM
BLK95-Z's Avatar
My 98 uses about a quart every 1500 also and doesnt smoke. I pulled the TB and oil was inside the intake.
Try a catch can or LS6 pcv conversion
Old Aug 6, 2011 | 05:39 PM
PheonixLS1's Avatar
I have pulled my TB, I have had it in the shop, hell even took it to Capitol Chevy here in VA and they gave me the write up. It's public knowledge about this motor so he very well may not have any problem at all.
Old Aug 6, 2011 | 05:42 PM
PheonixLS1's Avatar
Here's gm doc 2222953, word for word:
Document ID: 2222953
#01-06-01-011F: Information on Engine Oil Consumption Guidelines - (Jan 13, 2009)
Subject: Information on Engine Oil Consumption Guidelines
Models: 2009 and Prior GM Passenger Cars and Gasoline-Powered Light Duty Trucks Under 8500 LB GVW (Including Saturn)
2009 and Prior HUMMER H2, H3
2009 and Prior Saab 9-7X
This bulletin is being revised to update the warranty information on vehicles and add model years. Please discard Corporate Bulletin Number 01-06-01-011E (Section 06 -- Engine/Propulsion System).
All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the power stroke, part of this oil layer is consumed in the combustion process. As a result, varying rates of oil consumption are accepted as normal in all engines.
Oil Consumption
The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi).
Important: This rate only applies to personal use vehicles, under warranty, that are driven in a non-aggressive manner and maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or driven at legal speeds in an unloaded (for trucks) condition.
Important: This rate does not apply to vehicles that are driven in an aggressive manner, at high RPM, high speeds, or in a loaded condition (for trucks). Oil consumption for vehicles driven under these conditions will be more.
Many factors can affect a customer's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption.
Gasket and External Leaks
Inspect the oil pan and engine covers for leakage due to over-tightened, damaged, or out of place gaskets. Inspect oil lines and fittings for signs of leakage.
Improper Reading of the Oil Level Indicator (Dipstick)
Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked.
Notice: Operating your vehicle with an oil level that is below the minimum level indicated on the engine oil dipstick can result in severe engine damage. Repairs resulting from operating an engine with insufficient oil are not covered under the terms of the New Vehicle Warranty.
Important: Refer to Owner Manual in SI for checking and adding engine oil.
Not Waiting Long Enough After Running Engine to Check Oil Level
Some engines require more time than others for the oil to drain back into the crankcase. To assure a sufficient amount of oil has drained back to the crankcase, and an accurate reading can be obtained, the vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked.
Important: This does not apply to 2006-2009 Corvette Z06 equipped with the 7.0L LS7 and the 2009 Corvette ZR-1 with the 6.2L LS9 engines (dry sump). Follow the instructions in the Owner Manual for checking the oil in this application.
Improper Oil Fill After an Oil Change
Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner Manual or Service Manual for information on recommended oil quantity, viscosity, and quality.
Aggressive Driving, High Speed or High RPM Driving
Aggressive driving and/or continuous driving at high speeds/high RPMs will increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected.
A higher rate of oil consumption is normal for vehicles equipped with manual transmissions that are driven aggressively. By "aggressive," we mean operation at high RPM (3,000 RPM to redline), with frequent use of engine braking (using the engine to slow the vehicle). Vehicles that are driven aggressively may consume engine oil at a rate of up to 0.946 L (1 quart) every 805 km (500 mi). This is normal for a vehicle that is driven aggressively. No repair is necessary. This characteristic does, however, require the owner to check the engine oil level at sufficiently frequent intervals, especially when driving aggressively, to assure the oil level remains within the recommended operating range. As the Owner’s Manual recommends, you should check the oil level every time you get fuel.
Towing or Heavy Usage
Towing a trailer will increase oil consumption and may cause oil consumption to fall below the normal accepted rate referenced in this bulletin for an unloaded vehicle in a personal use application. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption.
Crankcase Ventilation System
Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use.
Oil Dilution (Fuel and Water)
On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, unburned fuel and condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture and fuel, may give the customer the impression of excessive oil consumption.
Engine Temperature
If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order.
Engine Wear
Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption.
Measurement of Oil Consumption
Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).
•Verify that the engine has no external leaks. Repair as necessary.
•Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual).
•Park the vehicle on a level surface.
•Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that the oil has had time to drain back into the crankcase.
•Verify that the oil level is at, but not above, the full mark on the dipstick, and that the proper viscosity and quality oil are being used as recommended in the Owner's Manual.
•Record the vehicle mileage, date, and exact oil level on the form included in this bulletin.
•Ask the customer to verify the oil level, each time the vehicle is fueled, following steps 1-6 and return the vehicle to the dealership if the oil level is found at or below the add mark, 0.946 liter (1 qt) low. If the oil level remains above the add mark, the customer should continue to operate the vehicle and verify the engine oil level until 3200 km (2000 mi) has accumulated before returning to the dealership for a final evaluation.
•If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 3200 km (2000 mi), follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 3200 km (2000 mi), explain to the customer that their engine meets the guidelines for oil consumption.
Old Aug 6, 2011 | 06:53 PM
LS1121's Avatar
Well that's all good but I bought my car new in Nov of 97 and i have never had an oil consumption issue. I installed my filter because of what every one here said on the subject. I use less than a quart every 10,000 miles, that is my oil change interval. The PCV system is the same as they have always been. In my 1964 Chevelle the vent went to the breather and was filtered by a little plastic clip on filter. My 98 did not come with a filter so I put one on because of what you guy's said and this is my result. About one tablespoon after about 3000 miles. On top of that I have a slight leak in my driver side valve cover so i am losing a little there. How do you account for me not losing oil?? I'm not blind and I'm not stupid either. lol
Old Aug 6, 2011 | 06:56 PM
ULTIMATEORANGESS's Avatar
Smile
a catch can will help and are recommended for LS motors.
Old Aug 6, 2011 | 07:08 PM
LS1121's Avatar
Yes that is where I am getting this little bit of oil from. I'm just saying large amounts of oil consumption is due to something other than a bad PCV system. I see a lot of people saying go to a LS6 Valley Cover. If you look at the LS6 Valley Cover, the line coming off it goes directly into the intake. It's the same as my PCV system, it is pulling oil moist air from inside the motor directly into the intake maniflod.......correct?
Old Aug 6, 2011 | 07:17 PM
Smile
all i can say is my LS1 in my SS used some oil and my LS2 in my GTO also did.
my H/C/I ls2 THATS now in my SS uses some but its getting better. hopefully my rings are still seating. im running a catch can on this motor.
BUT, my experience, even my tuner says its normal for these motors to use some oil.
they tend to vary how much but its not uncommon for them to use some oil and not smoke.
Old Aug 6, 2011 | 07:22 PM
PheonixLS1's Avatar
Never said you were blind or stupid. But, if you read the document presented, it doesn't say YOU WILL have this consumption. It said the ACCEPTABLE consumption rate is 1 quart per 2000 miles. That being said, again, just cause your car doesn't do it doesn't mean another one won't. We may all have the same motor but none of them will be replicated perfectly the same as the previous one or the next. Obviously GM realized that this can be an acceptable issue and made the public aware so they would know there is nothing wrong. Now, will the suggestions ya'll have made clear the consumtion problem? Maybe! However, that still doesn't mean there is something "WRONG" with the car b/c its consuming the oil at the suggested rate.
Old Aug 6, 2011 | 07:26 PM
Smile
i got a letter from GM saying my GTO will use some oil if i drive it at high RPMs regularly.
especially with a manual so LS motors do use oil and GM is aware of it.
Old Aug 6, 2011 | 08:12 PM
LS1121's Avatar
OK BUT the OP said he had 1200 miles and he used a Quart of oil!! and then someone chimmed in said that this was NORMAL.. wrong that is not Normal. I don't understand how someone can make a statement like that and not expect to be rebuffed. If this is the case then LS1's are the worst motor ever built. lol
Old Aug 6, 2011 | 11:15 PM
PheonixLS1's Avatar
Actually I guess you are blind cause the OP said 1500 miles and 1 quart of oil. SSSOOOOO if he has a heavy foot, as the supporting document states, he will burn up more oil than the acceptable rate of 1 quart per 2000 miles. That means every 500 miles is 1/4 quart, break that down to the 500 miles missing to get him to 2000 miles ( as he stated he is at 1500 ) he is consuming 1/3 quart per 500 miles. Which would in fact be within the peramitters (spelling) of the supporting document if he has a heavy foot. So you may not be blind or stupid, you just cant read and then you try to bash me when I present black and white fact. We don't know his driving habits, we can only assume from the numbers he gave us to fill it into the equations presented by GM's document and go from there. COULD there be something else going on?? Sure, but why have somebody waste their time and money throwing "suggestion" parts into the car. Have a machanic properly diagnose the car and see what you find instead of playing the guessing game, it may just indeed boil down to normal consumption. Also keep in mind that if he has an M6, the supporting document also states that if he drives aggressively ( i.e. engine breaking and rpms 3000 to redline) that he can consume 1 quart per 500 miles!!!! Well holy sh&t, lets change your PCV system, all your gaskets, your oil pump, pull your TB, hell rebuild that whole ***** ***** just to find out there was nothing wrong. Well YEE HAW!!!!! (sorry for the rant lol) Not trying to be an *** but read the whole document before you "rebuff" me as you put it. Its all there in plain ole black and white.
Old Aug 6, 2011 | 11:47 PM
LS1121's Avatar
Not trying to be an *** ... your doing a pretty good job at it.
Old Aug 7, 2011 | 12:02 AM
LS6427's Avatar
That bulletin should simply tell everyone that the vacuum strength is just too high. All people need to do is what I did and their oil consumption will stop and they will still have plenty of crankcase vacuum suction to deal with crankcase gas evacuation.
Put a needle valve in-line so you can adjust the vacuum strength going into the intake........problem solved.
I just played around until I found a setting where I had ZERO oil in my intake anymore and NO MORE oil consumption.
You can see the plastic "T" valve with the metal torx screw to act as the adjustment valve.
Old Aug 7, 2011 | 09:50 AM
LS1121's Avatar
This is interesting...thank you. This thread is actually turning into a USEFUL conversation. I personally don't have an issue with oil consumption, why I'm not sure but I and probably others would like to hear more on this vacuum reduction theory.
