problems pulling out crank pulley bolt
Old 08-31-2011, 11:54 AM
bugy's Avatar
Unhappy problems pulling out crank pulley bolt
well i've been trying to remove crank pulley, just brought down steering rack but noticed can't stop engine from turning then bolt can't be loosened, is there any way which i can hold engine from turning. or what am i supposed to do to pull it out? can't see flexplate neither. This is a 98 c5 vette.
Old 08-31-2011, 12:47 PM
RARON455's Avatar
put the ebrake on. It takes alot of power to get that bolt loose,,youll need a breaker bar for sure.
Old 08-31-2011, 01:27 PM
99screamindemon's Avatar
manual trans? or auto
Old 08-31-2011, 01:35 PM
bugy's Avatar
it is auto trans
Old 08-31-2011, 01:39 PM
Restricted User
z99ls1's Avatar
Ha when you see the title from the main ls1tech page it just says "problems pulling out" lmao. I figured op knocked somebody up..
Old 08-31-2011, 01:41 PM
bugy's Avatar
if you were meaning to handbrake, it is auto trans :S about breaker bar i suppost it is a tool or something, im still stuck
Old 08-31-2011, 01:44 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Impact gun. That is what you need. Brap! bbbbrrrapp!
Old 08-31-2011, 02:08 PM
bugy's Avatar
lol, that's funny
Old 08-31-2011, 02:54 PM
01ssreda4's Avatar
Kent Moore flywheel holding tool.
Old 08-31-2011, 05:40 PM
bugy's Avatar
thank you guys, i used a impact gun but one more powerful which i have and i worked
Old 08-31-2011, 07:17 PM
01ssreda4's Avatar
How you gonna tighten it properly?
Old 08-31-2011, 09:07 PM
Restricted User
z99ls1's Avatar
Good point lol
Old 09-01-2011, 01:34 PM
Internet Mechanic
Well to get it off, its not important but when reinstalling, like said you need to hold the flywheel since its an automatic car. If it was a manual, you just need to be in gear.
Just remember, some lube, a threaded rod with some washers and nuts to draw the UD pulley back on, and then use a new crank bolt. I use ARP.
Old 09-01-2011, 06:02 PM
Pocket's Avatar
Use a ratchet strap hooked to the chassis and one of the balancer ribs. Works great for breaking it loose and torquing it
Old 09-01-2011, 09:33 PM
LilJayV10's Avatar
I have a reply but I'm afraid someone might take me seriously and the last thing I want to do is be the cause of someone fubar'in their crankshaft threads. That and it wouldn't be a useful post.
