Is there an agreed upon best TB for ls1 stock cubed, h/c with the 102 yet??
Old 10-08-2011, 11:05 PM
gateman's Avatar
Default Is there an agreed upon best TB for ls1 stock cubed, h/c with the 102 yet??
I have read through countless pages on TB's for the 102 intake.. Some say get
NW 102 tb while others note tuning issues on idle/low rpm?.... Others say get
A ported 92 tb... Then it seems also that the stock ls2 tb is also good, but requires electrical adapter harness and porting.... So on a stock cubed, afr205, mid size cam, yell a terras, fast102, 48#'s, upgraded fuel system car..... Is there a general consensus on who is the overall winner or best choice TB to work with new 102?? Looks like I am leaning toward a SD tune to avoid the MAF issues and cost, is that a good idea or bad idea? Car is not a d/d just a toy, so some drivability can be comprised slightly.. Thanks..
Old 10-09-2011, 12:50 AM
printmanjackson's Avatar
I think it depends on what you're going to do with the car and where you want to make power. Bigger is not always better
Old 10-09-2011, 12:56 AM
Suzaku's Avatar
Unfortunately no, all 102 tbs perform the same at WOT, however the difference in performance is getting to WOT, and there isn't much power to be lost in the between time.
I'm going to get the FAST 102 TB, they supposedly fixed the sticking blade with dual TB springs, so hopefully it'll be well worth it.
Old 10-09-2011, 02:30 AM
99Bluz28's Avatar
I would think even a unported 92 TB should be big enough.
Old 10-09-2011, 09:16 AM
cookba's Avatar
havent seen issues with NW throttle body's. I know the FAST units had some issues that may have been worked out. But I like my NW 92, its a quality piece. Going SD wont be an issue as long has the tune is spot on, you will notice some driving differences when there is a change in the weather. But since you dont DD the car i dont see any problems.
Old 10-09-2011, 09:46 AM
SweetS10V8's Avatar
The FAST throttle bodies are the way to go. I've seen too many NW and others not seal the intake. this is because everyone designed a throttle body and FAST designed throttle bodies to fit the manifold
The FAST 90 mm throtle bodies are the ones that had sticking issues. the 92 & 102 throotle bodies are a 100% redesign.
No one needs a 102mm, but if you get one the FAST has a build in convelute to help with tuning and low speed throttle control.
Old 10-09-2011, 10:05 AM
the LS2 90mm TB fits nice too.
Old 10-09-2011, 01:31 PM
SweetS10V8's Avatar
This too is correct. It was also designed to fit with OEM DBW throttle bodies. I ran the 90mm LS2 throttle body myself.
I also think this car is better off being tuned with a MAF.
Old 10-09-2011, 04:31 PM
_GTO_'s Avatar
Are u putting that TB on a 102 fast intake directly ?
I mean didn't u port the back of the TB to match the manifold inlet , or did u use the "ring" .
Old 10-09-2011, 08:02 PM
SweetS10V8's Avatar
No it doesnt need it. Ive used the OEM 90mm LS2 TB many times without an issue. I think its snake oil myself......
Ive seen the thread about the ring and asked this...
I run a GM LS2 90mm DBW throttle body on my FAST 102mm and dont notice anything.
Here is what I always came back to, when you install that ring, there is the same edge. Its now just farther back. You would have to make it with a bellmouth or trumpet and have the tapered part inside the manifold to get rid of that edge.
Old 10-09-2011, 09:04 PM
gateman's Avatar
thanks, looks like a ls2 tb is for me and i will get a 85 maf and stay away from the SD tune for now.. Do i need the v-ring?? what about adapters for the ls2tb?
Old 10-09-2011, 09:11 PM
qkslvrz06's Avatar
Is there much to be gained with the 102 on a stock cubed ls1/6. To get all the benefit of the 102 wouldn't you need to increase the size of the MAF and intake duck? I am piecing my build together and the local tuner doesn't like after market MAFs so why restrict then increase size? What is everybody running?
Old 10-09-2011, 11:39 PM
you will be fine with the LS2 TB which is 90mm and the 85mm MAF.
I went with the V ring.
Old 10-10-2011, 07:27 AM
SweetS10V8's Avatar
Its not the throttle body size that makes power. Its the runners inside the intake that make the power. The throttle body only makes more power when its a restriction.
A 90 or 92mm, with the 85mm Vette/truck MAF, is plenty of 99.9% of people.
This intake will make 20-25hp over an LS1/LS2 intake and 10-15hp over an LS6 intake, on a totally stock engine.
Old 10-10-2011, 07:06 PM
qkslvrz06's Avatar
Thanks for your input. That's the route I was leaning toward. Is there anything to gain on a ported 90 mm tb?
Old 10-10-2011, 09:04 PM
SweetS10V8's Avatar
As with all porting, it depends.......
I know there is about a 5-7hp difference between a 90mm dbw and an aftermarket cable 90mm. So its possible.....
Old 10-12-2011, 10:13 AM
are you saying a DBW TB produces more HP?
