BBK Longtubes and y pipe to Magnaflow cb?
I have heard a few people say that the BBK y pipe is the same diameter as some catbacks. Has anyone installed these with a Magnaflow catback? Any mods need to be done? I searched for pages but couldnt find anything. Thanks.
The exit on the bbk y-pipe(inside dia.) is sized to slip over the factory I-pipe(2.9" OD) with just little bit of wiggle room(about 1/16"). IMO, buy a cheap $4 micrometer to measure the OD of the I-pipe for your cat-back and the ID of the bbk Y-pipe merger exit. If the OD of the I-pipe for your chosen cat-back is over 3" then one of the pipes will probably need to be slightly expanded to slip fit.
The Scammer Hammer
Jeez.... Scratch that then. Thanks for the heads up. It worked for me and an HKS Stainless around 5 years ago. Well, then again, that was when stuff still said Made in USA.... Looks like I won't be buying a new one since I've since lost that one in the move.
I-Pipe to the shop it is then.
i have the bbks going into a magnaflow. since the magnoflow was on the car prior to the longtubes it required some heating and pounding onto the y. maybe an extra 5 minutes of work but it was due to it being clamped down before. if its a new system then it should have no issues going on.
I take it im the only one whos magnaflow i pipe was too short to reach the y with this setup? After a ton of annoying work trying to get pipe to fit into the y, we put the y pipe on the car and went to put the i pipe on and they barely touched eachother. I mean I guess we should have test fit everything before we did all that work, but technically we shouldnt have had to. I bought both the headers and y and the magnaflow systems brand new. And the magnaflow fit perfect with my pacesetter y pipe.
You should never use an impact gun on a pipe expander. A 1/2" breaker bar is all you need.
After the third try we broke the Harbor Freight expander with a 1/2" breaker bar. If we had used an impact it would have exploded on the first try hah. Any sort of puller or expander you should use hand tools. When you say it didn't work do you mean you couldn't get enough leverage on it to expand the pipe? We had no problem expanding it before it broke, my breaker bar is about 24" though.
I am going to weld an extension onto my existing magnaflow i pipe and butt the pipes up even with one another. That clamp is supposed to seal pretty well apparently.
