Old 04-25-2016, 04:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
what intake is best for ls1
Old 11-06-2011, 09:05 PM
spiro27's Avatar
Default what intake is best for ls1
i was considering the new fast 102 intake but after hearing not so good feedback about it and all the work needed to install. i desided not to plus the price too much work for that price and not that much hp gain. i was thinking of just keeping my ls6 intake that came with the car. what do you guy rec. is there any worth wile mods to do to the ls6 intake. and how big of a tb can i put on it. my car is gona have heads and cam on it so i like to impove the intake. what other intakes are worth it. thanks for the help. i will also be changine inj for my setup too.
Old 11-06-2011, 10:46 PM
sjsingle1's Avatar
the best thing you can do with a LS6 intake..........is move up to a 102..........no ifs ands or butts
Old 11-06-2011, 10:59 PM
The Scammer Hammer
dr_whigham's Avatar
I think the best thing to do is get a Shaner S3 TB and throw that on. I'm in the same boat as you. My car is a STREET car, not a track car, and as being such, I simply can't justify the price.
If I was racing on the weekends though, you're damned right the 102 would be my first coice though.
Old 11-07-2011, 11:52 AM
spiro27's Avatar
is the bbk or holly manifoild better than ls6. they seem resonalby priced. do they sitll sell the fast 92 manifoild.
Old 11-07-2011, 12:28 PM
777's Avatar
No they aren't. Ls6 is best unless you go either fast lsx or edelbrock victor jr. (nitrous or FI)
Old 11-07-2011, 12:57 PM
zacht's Avatar
im going to throw an oddball vote out there for....
a weiand street warrior!!!!
no but seriously. try and find a used fast 78, 90, or 92. i would think theyre the best due to cost comparted to a 102...
Old 11-07-2011, 02:38 PM
Fry_'s Avatar
I had a weiand street warrior on my car and it was AWESOME. But it got ruined when I was driving home one night and hit big foot. It totaled my 2005 Trans Am WS6.
If you believe anything I just wrote then I've got some ocean front property to sell you here in Iowa.
I say save your money for your H/C set up, the extra money could be the difference between a set of ported 243's and being able to buy some AFR Mongoose heads. I've seen a few threads where people have ported there LS6 intakes to fit an 85mm TB.
Old 11-07-2011, 02:54 PM
777's Avatar
I didn't think there was an ocean near Iowa
Old 11-07-2011, 04:22 PM
VandykeT/A's Avatar
Grind the water pump and buy the necessary parts for it and its not that much trouble. I would however relocate the MAP sensor becuase it is very close to the firewall. I"m just waiting for mine to get a little extra movement and break off. A used FAST is probably gonna be pretty hard to find plus you may end up with someone elses headache. I'd just keep the LS6 intake until you got heads and cam. Make the intake your last mod. X2 on the Shaner S3 those are works of art. It'll give you great throttle response.
Old 11-08-2011, 03:04 PM
Captain Double Post
BOBS99SS's Avatar
Op you have been misinformed about the 102. Your ls6 is fine for now. Honest on a head and cam car the fast intakes beyond shine.there is no cheap upgrade from the ls6 unless you sell it and find a older used fast intake.but its not really worth it untill at least a cam gets in there.as far as the TB goes just stay with your ported stock one.there is no need to spend money on a TB untill the h/c have been done. I swear the more threads i read i just hear about people wasting money.there is so much you can get out of these cars and do it on a budget.
Old 11-08-2011, 04:07 PM
SweetS10V8's Avatar
I agree, they are not any harder to install than any other intake. If you read the directions there will be no issues at all with the install.
Here is where I dissagree with you, I have done a TON of FAST intakes on non H/C cars and they still make ~20hp
My stock LQ9 shortblock, stock cam, with LS2 intake, swapped to FAST and gained 21rwhp. No tuning
2007 Silverado 5.3L with TBSS/NBSS intake, 100% stock, swapped to FAST and gained 20rwhp, no tuning.
1998 Corvette, Ls2 swap, Heads and cam, gained 20rwhp over stock LS2 intake
The point is, they work just as well on H/C cars as they do on stock cammed cars.
Old 11-08-2011, 04:16 PM
ULTIMATEORANGESS's Avatar
Smile
i guess theres a few metal heat soaking manifolds you can go with but i went with a FAST.
Old 11-08-2011, 05:32 PM
Captain Double Post
BOBS99SS's Avatar
Sweets when i get to my comp ill clear some things up on my post.hard as hell to type on this phone.i will say i was meaning a fast on a stock internal car is pointless. And gains will depend on setup,if the intake is ported,and how high your going to spin it. I will explain more tomm. Im putting a ported fast on my cam only car i wish i had the synopsis sheet but i haven't made it that far yet lol but that would help show what im talking about
Old 11-10-2011, 05:32 AM
ausls1's Avatar
i'm thinking of the Lingefelter, i think that's the company, do a modified ls6 manifold with a 90mm intake opening and throttle body, they had dyno results on the same motor with only a couple of rwhp difference, maybe 5hp at the most.
Here's the link, sorry i was wrong, it was 4hp difference between the ls6 modified and the fast 90, there on the two graphs at the bottom, both compared to a ls2 manifold.
also has a option if you send yours in for a modified one which makes it a very cheap manifold for the price.
http://www.lingenfelter.com/mm5/merc...w=&range_high=
Old 11-10-2011, 05:48 AM
Captain Double Post
BOBS99SS's Avatar
auslls1 there is a company you can send your ls6 to and they will put a 90 mm snout on there, i have talked to people that have had it done and they were no to happy with the cost and the quality of work done, i honest would just stick with your ls6, all your going to do is over pay . i have seen dyno graphs on the fast and ls6 on stock internal ls1s, and honest i didnt see it beeing worth the extra money when the motor still has stock internals, a ls6 will flow beyond its fair shair for a 300 dollar intake, and the cost of even a used fast with tb could pretty much pay for a cam swap. i guess is what im saying is i would take a cammed ls1 with a ls6 over a stock ls1 with a fast lol.now if you really wanna talk what is the best intake imo its a mamo ported fast, some will say its a over priced port job and it is expensive but there is a pretty big gain over a untouched fast. worth the money?some think so , i just will port my own lol
Old 11-11-2011, 06:53 PM
spiro27's Avatar
my car has head and cam already. longtubes. is there anyware to send out my ls6 int ake to get ported and get it to take 90 mm tb
Old 11-11-2011, 11:45 PM
SweetS10V8's Avatar
There is, but your better off selling your LS6 intake and buying a used FAST intake in the end.
Old 11-12-2011, 06:54 AM
ausls1's Avatar
oh ok, all good then, yeh mines getting a 383 stroker kit as we speak and will run a decent cam 235/243 113 lsa from comp, if its worth it i'll swap to a fast 102 manifold with a 92 mm throttle body, other wise will stick with ls6, but the fast might be worth it then in my case?
Yeh when i first read about the ls6 mod i was a bit suss on the craftsmanship with it being a one piece intake.
Old 11-12-2011, 10:05 AM
Tobias05's Avatar
i want one of those magnacharger intakes. the kind that whistle.
...but on a serious note, i'd try to find a used fast. i'd be happy with a 78 even. that way i can reuse my shaner.
Old 11-17-2011, 09:32 AM
sprayinracin's Avatar
FAST 102 > *
LS6 intake is sufficient for guys on a budget
Quick Reply: what intake is best for ls1
