Best exhaust clamps to go with TSP set up
I have the TSP 1 7/8" headers and true duals dumped. The clamps always end up leaking aftrt a couple months. i normally use permatex exhaust sealant. are there any better clamps i can use or should i try switchkng to high temp rtv? thanks!!
Use the soft malleable band-clamps. Pep-boys has them sometimes, usually not enough on the shelf for a whole system. Jegs, Summit, whatever should have them, too. Usually about $6-8 each.
LS1Tech Premium Sponsor
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I don't have TSP's setup, mines all ebay.
I used 3" stepped band clamps from jeg's (stainless steel). I've had no leaking issues with them at all. As a matter of fact, other than the headers (to the block), everything is just clamped...with the exception of the mufflers which are bolted to the rear seat buckets.
