Steam tubes?
Old 12-02-2011, 05:23 PM
86lxnotch's Avatar
Default Steam tubes?
Putting a lq4 into my foxbody and trying to figure out what every1 does with the steam tubes? i'd like to connect the rears as well. i was thinking about tapping them 1/8'' npt and running lines that way and connecting to up front but how should i go from there? using a alum rad for the fox
Old 12-02-2011, 07:21 PM
bluenightmare's Avatar
I sent you a pm with the website that has adapers to put an fittings for your steam pipes without any modification to your heads. I ran my steampipes eternally over the heads with rubber hose. If i can send you pics of how they are run.
Old 12-02-2011, 07:47 PM
86lxnotch's Avatar
thanks, im thinking i may pickup a stock ls1 steam tube setup and then tap my waterpump to hook the hose up to and call it a day.
Old 12-02-2011, 08:28 PM
That's MISTER MODERATOR
Paul Bell's Avatar
86, welcome to LS1tech!
It's a good idea to retain and use the rear steam fittings.
Old 12-02-2011, 08:37 PM
86lxnotch's Avatar
thanks paul, right now it has the blockoffs on the back and i knw how the mod motors(03-04 cobra mainly) have cooling issues in the rear cylinders as well. since i plan on spraying this i want it "safe" lol. this setup will be interesting cause its goin in my notch which is setup for 8.50's. my old sbf/turbo it went 9.27@134 lifting so a nice shot will make this interesting
Old 12-02-2011, 11:48 PM
99 PROBLEMS's Avatar
post some pix of it, i'd like to see it.
Old 12-03-2011, 07:28 AM
86lxnotch's Avatar
here is dyno vid before i had ported heads on it. i have track vid somewhere
http://www.youtube.com/watch?v=U7sWAoVzEz4
Old 12-03-2011, 08:21 AM
Paul Bell's Avatar
I like the color!
Nice ride.
You just need some LSX stickers on it....
Old 12-03-2011, 03:57 PM
86lxnotch's Avatar
lmao thanks but the ONLY sticker it is my buddies shop sticker and thats even small and centered in the back window
Old 12-05-2011, 10:00 AM
this is how i have my steam pipes run up over the intake manifold. I need to pull them back off and do some trimming, but it is working fine for now.
Quick Reply: Steam tubes?
