Fast 92 Over LS6 Intake?
So is it worth buying a Fast 92 over keeping my LS6 intake? Or should I just wait & save up to get a Fast 102? What could I expect from power gains?
Because everyone is scared to run a 102 over a 92. I plan to put one on mine along with LS6 heads and a small cam. 102 will gain on even a stock motor even with a 102 TB. The TB size determines the CFM the motor gets, the runners and intake ports determine velocity. People need to stop thinking in terms of running a carb. 102 loses nothing down low and pulls away from everything else at 4k
I could be wrong...maybe someone with a 102 intake can chime in. I know on my 92 the neck on the intake sticks past the water pump and it's actually touching the top bolt on the water pump. I thought I was going to be forced to grind some off the bolt tab or intake but it just made it...and this is on a 92mm intake.
Nevermind....it looks like they shortened the neck on the 102's by a good couple inches so this wouldn't be an issue. It appears to only be a problem with the 102's like you said.
