Where can i get one of these (pics)
I need a p/n or a place thats sells the part pictured below. Go goes behind the intake manifold to the firewall i believe.
Dont ask how it got lost im still pissed about it.
Also the gray plastic c-pic that connects the vacuum hose to the throttle body.
What were you doing to expose it...If your getting rid of your air plug it and the intake port it goes into...I'm in the middle of installing my ls6..Mines still back their....I could probably fish mine out and give it to you..
Awsome thanks guys, I'm actually going to go and check and make sure the entire system is gone, told the guys that did my h/c job to delete the AC and AiR. If the hose was hooked to the back of the manifold but not the fan looking thing could that be causing me to stall when i clutch it and roll to stop (only happened like once or twice.
It's likely...I had a pin size hole in my pcv hose that would cause a stall while shifting into reverse.. Any tiny vaccum leak can cause problems with our sensitve engines..
So just to be certain, I am only capping off one tip (the one on the back on the intake manifold)? There is nothing on the other end because that goes to the big black hose that is gone now?
I realize I'm asking stupid questions, its just very cold this week and I have not had a nice day to go outside and get under the hood yet.
ehh take it or leave it, rather have a clean engine bay
Dont drive in the winter much. However, the actual firewall section of the A/C containing the heater core is still there. Would have already deleted it if i didnt have to pull the dash. If that matters much.
I'm not hardcore enough to remove that stuff. I've pulled the dash for other reasons, but really it's not that hard.
