car still not running right 98 camaro ls1 A4
first an 2nd time after motor was redone ran perfect i mean perfect few days later wouldnt start at all!!!! Changed tps finally ran again but not good at all i moved it an ran fine but idle messed up it was reving its self to 2g then back down to 1g then flooded out!! Wouldnt start anymore check engine light scanned it tps low voltage fixed that an set it at .69-.71 volt. changed plugs cause flooded started up ran perfect healthy then once i put in gear it wanted to drive its self an stalledA4 then in gear again idled at 2g an drove its self an stays at high idle unless back in P or N an its idiling from 2g down to 500 to 1500 to 2000 an keeps goin an stalls wtf no check engine light anymore also gota change oil since i got gas in it from floodin it ahhhh myb bad iac?? myb tunner had it tuned at vengeance racing its running rich
vacuum leak or tune issue would be my guess. start it up and spray starting fluid of carb fluid around the intake manifold and vacuum lines to see if it changes the way it runs.
Try to avoid using brake or carb cleaner to find vacuum leaks, many a car went up in flames using that method. I heard lots of stories from the old timers I worked with for years and have seen fires myself. Use non flammable brake clean, or a spray bottle with water.
Update well I plugged hole in tb blade put y pipe on reset tps again an car started up few times bad then kept recon it then I got a set idle an was running fine again like it use to an then check engine light came up an codes where maf /vaf low voltage so I have a bad maf sensor now an would a bad maf cause a idle to be lil Higher it's idling at 1100 I have a tune from
Vengence racing an I also got a code for tps pedal positing sensor
