How did you wire your cutout?
ok so i am trying to decide where to get the wires from the cutout right after the y-pipe to inside the cab. does anyone have pics of how they wired theirs, and where you plumed the wires into the cab? i would prefere not to drill a hole but if it has to be done, then so be it.
i have a QTP cutout with the stock toggle switch and the light on the tip.
FOUND IT! it is in a great spot. now the next question
i have my switch in the ashtray area, where did you guys tap in for power and ground with out having to run it strait to the battery? i would like it on switched power so it is only available when the car is on.
i was thinking about this as well, with the convert top button as i am aware it has been done before. for right now i taped in to the cigarette lighter, but i dont like the power from there as it is constant power and the little light on the switch stays illuminated. but if i went with the vert top button then it would be stealth and clean! no light either.
check out this thread for the Vert Button for the cutout.
https://ls1tech.com/forums/stereo-el...-question.html
i am probobly gonna do this.
I ran mine through the drain plug under the passenger seat and it comes out like 2 inches from the cutout...perfect. I also put my toggle switch in the ash tray. I used the ground from the cig lighter and hot from my old stereo harness.
http://www.youtube.com/watch?v=UuKZn...3oIUCaheeq9KJE
hey Jarhead (lol, jarhead) why did you cut your tail pipes and make turndowns right before the bend? i think T/A's look way better with tail pipes and camaros look better with out. just curious, not criticizing. i used the passenger back seat grommet. great little spot. which wire of the stereo is switched power and which one is constant?
to be honest i totally agree with the pipe comment. I have been a mustang guy forever thats prob why i did the turn down.....jk. I had straight pipes before and it sounded like ****. I would like to find a cheap borla or corsa CB...then I may put tips back on.
For the wire I just got a test light and tested which one was live with the key on.
