coil brackets
coil brackets
ok i just got some 243 heads i am putting on my 98z to replace the 806 heads. do i need some sort of different coil brackets seeing that the valve covers are diferent? what are my options
Yes, the 98 you have came with perimiter valve covers, the coils bolted to the cover itself,, however when you change to the centerbolt covers, you have to use a bracket, to mount the coils on, and that bracket mounts to the valve cover . put the coils on the bracket before putting it on the valve cover...
i am getting both yes and no from different sources on whether a ls1 coil will fit a truck bracket so i went and got them being that they were free. i will post my results
which ones are the newer brackets i now have one of each. one has rectangle holes for the coil to sit and the other one is open on one end
undertow74 would you sell just the brackets with bolts how much shipped to 70663. please pm me
