Electric cutout function.
I was hoping someone could give me some insight. Do electric cutouts function full open full close or can you hook one up to open at certain angles? Want to put one on my borla adjustable but want to be able to meter partially through muffler.
The cutout that was installed on my '02 when I bought it was electric and had a 3-way rocker switch to control the cutout: one position closes the blade, one is "neutral", the last opens the blade. While it is possible to have more than just wide open and totally shut in this case, from what I've read most e-cutout manufacturers say to not have it in any position than open or shut, and in fact I think most will try to void your warranty if it is operated in a partial-open state (if they could even tell....)
My QTP can be opened partially.
From there FAQ.
Q: Do I have to run the cutout wide open when I open it?
A: Not at all, you control as much volume from the cutout as you like. You have total control over this using the supplied momentary toggle switch or one of our other optional controllers. Just want a little bit louder? Give the switch a quick tap down. A little more? another tap... and so on.
Untrue.
From there FAQ.
From there FAQ.
I built a cable operated one from a northstar throttle body. Course it was easier said than done, but instant response.
http://www.youtube.com/watch?v=n3mL8...6&feature=plcp
I have a DMH e-cutout on my borla (in place of the adj. plates) and like mentioned above, you can adjust to be open at any angle...beats having to get under the car to swap out plates and can do it while driving too.
Here is a pic of mine (sorry not the best pic for to see the cutout), but you can see the e-cutout wiring going up and to the left in the pic (there is a rubber plug in the floor there that you can pass the wire thru to run it into the cabin)
