trex cam and 5.3 stage 2.5 heads
Old 03-10-2012, 06:33 PM
mikh338's Avatar
Default trex cam and 5.3 stage 2.5 heads
i know this is a very large cam and I cant seem to find any info on the PTV clearnence, I want to run the 5.3 stage 2.5 heads with my Trex cam. Will this combo work?
Old 03-11-2012, 12:13 AM
garygnu's Avatar
call thunder racing .
Old 03-11-2012, 01:04 AM
Ronny_02_WS6's Avatar
I think those heads only offer till 63cc check with TSP also, i believe with that cam you should have 64cc or more, not sure though.
Old 03-11-2012, 10:17 AM
mikh338's Avatar
alright, yeah ill call thunder racing
Old 03-11-2012, 02:27 PM
camarodude87's Avatar
Yeah thunder never replied to my emails. I went with 243's ported by AI. made 480 to the wheels. If you get just the head job its a amazing deal, I sent off my fast 92 as well
Old 03-11-2012, 04:05 PM
NemeSS's Avatar
U will need to verify ptv with that cam no matter what. More than likely will need to cut valve relieves. Don't expect to just drop in as is
Old 03-11-2012, 07:17 PM
mikh338's Avatar
awesome numbers, stock cubes?
Old 03-11-2012, 07:18 PM
mikh338's Avatar
alright i will make sure to give them call and check before i do anything
Old 03-12-2012, 02:57 AM
Yeah man stock cubes, and yes I did have to fly cut with my set up. Well worth it.
Old 03-12-2012, 10:00 PM
garygnu's Avatar
I believe with TSP 5.3 heads TSP can sink the valves deeper into the valve seat to gain move PTV.I would degree and double check clearances with a cam like that.
Old 03-13-2012, 01:23 PM
mikh338's Avatar
i emailed them yesterday still no response
Old 03-13-2012, 02:30 PM
BrntWS6's Avatar
Call TSP, I'm sure they have dealt with that setup before. And they usually answer their phone.
Old 03-14-2012, 05:04 AM
Believe me, Go with AI...
Old 03-14-2012, 08:25 AM
mikh338's Avatar
i cant spend $2k+ on heads
Old 03-15-2012, 12:34 AM
find yourself a cheap pair of 243's and their best port job is only 995 http://www.advancedinduction.com/LSX...cGMLS2Head.php
Old 03-15-2012, 09:27 AM
mikh338's Avatar
i have oversized valves, comp 921 dual springs, titanium retainers, comp hardened pushrods and ls7 lifters. are those compatible with 243 heads?
Old 03-15-2012, 09:47 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
In my opinion, that cam is too big for a stock long-block AND for an engine with the Stage 2.5 5.3's. The few we've had come through here that we got the chance to check PtoV clearance were VERY tight. If it were mine, I'd only run an aftermarket casting that had better than stock valve-drop.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 03-15-2012, 02:10 PM
mikh338's Avatar
well my current setup is a forged LME 370 with trex cam all stock top end. what do you suggest for heads? i only was thinking of the 5.3 stage 2.5 heads since they are a good price and flow well. I really didnt want to spend a lot of money on heads but my choices may be limited.
Old 03-15-2012, 02:36 PM
Aftermarket short-block changes everything! Most any aftermarket piston will have a valve relief in them so you can run much more aggressive combos with good clearance! Do you know the specs on those pistons or have the piston part number?
__________________
Old 03-15-2012, 03:15 PM
mikh338's Avatar
wiseco forged 4.030 pistons.
Quick Reply: trex cam and 5.3 stage 2.5 heads
