what is this? fast question?
Old 03-16-2012, 04:21 PM
z28oc91's Avatar
Default what is this? fast question?
hey guys i have a couple of questions i encountered while installing my fast 102. sorry if this has been covered but i have not seen it.
in the back of the ls1 intake their is a sensor and on the fast their is not? so does this sensor necessary or should i just leave it off
the fast has a small line coming from the back and im not sure what this is suppose to hook up too?
aslo finally when i was mocking up the fast on top of my engine in the back this piece fell off? i am wondering what is this and if its broke? i do not think i cracked it up im not sure how to put it back on
here are pics down below, thanks for any input!
Attached Thumbnails what is this? fast question?-getattachment.aspx.jpg   what is this? fast question?-fast-back-side.jpg   what is this? fast question?-sensor.jpg
Old 03-16-2012, 04:29 PM
Big Black SS's Avatar
the last pic. looks like you broke your oil pressure senser ... just broke and replaced mine ($60)
Old 03-16-2012, 04:40 PM
thunderstruck507's Avatar
First pic is the MAP sensor, it is a must have. Should be relocated on the 102 if I remember correct.
Broken piece is the oil pressure sensor as mentioned above.
Old 03-16-2012, 05:33 PM
z28oc91's Avatar
wow i feel like a fckin idiot haha, okay now that i know that i looked it up, basically just get the right socket take it off and put the new one in correct?
Old 03-16-2012, 05:35 PM
z28oc91's Avatar
jw you said its relocated..is it on the intake? i dont not remember seeing another port on it but i will take another look
Old 03-16-2012, 05:40 PM
torkls1's Avatar
Haha I wouldn't feel like an idiot, a lot of people break the oil pressure sending unit (opsu) while changing out intake manifold. You can get the opsu for about $30 at autozone. Ya, just unbolt the old opsu and bolt in the new one at 15 ft/lbs.
Old 03-18-2012, 04:19 PM
z28oc91's Avatar
Thanks for the replies guys. Now I know what's going on, but does anyone know what that small hose is for I the back of the fast intake?
Old 03-18-2012, 05:56 PM
baxsom's Avatar
is that the HVAC vacuum line?
