MSD/mini starters
I tried the Summitt adjustable mini starter SUM-820320 - Summit Racing® Protorque starter . Adjusted one way it hits the headers with the solenoid . Turned it in and now it hits the sender above where the starter mounts . Anyone used this starter ? What is that sender above where the starter mounts ?
starter
My opinon to anyone thinking if getting this starter : If you have headers , get something else .
I ended up getting a truck starter for a 2000 Silverado 6.0 . It has the block that uses the two long bolts as opposed to the one short and one long that the car starter ha . It also is a little smaller .
The truck starter and alternators seem to be good buys. Several people have posted good results with them. I went with a Powermaster starter and yes with long tubes you have to move it around to fit. The PM is completety clockable in any direction, some only have a couple adjustments.
The Scammer Hammer
truck starter
Time was the main reason . I have to send the Summitt back and then order a MSD . I wasn't too sure about a simple bolt on for the MSD where the truck I knew would bolt in . Price was good too . Truck starter was $169.00 at Auto Zone .
