Which MAF, i THINK mine died.
Old 04-18-2012, 08:05 PM
White94Bird's Avatar
Default Which MAF, i THINK mine died.
https://ls1tech.com/forums/general-l...-stumbles.html
THeres the story, guess I'm gonna have to replace it but with what?
A 85mm will need a tune correct? And a stock one is a 3 pin?
Old 04-18-2012, 10:29 PM
dodson55's Avatar
Do a SD tune and throw the maf away lol
Old 04-18-2012, 11:05 PM
Siciliano15's Avatar
yea either that or get a new stock one and take the screen out of it and if you have hp tuners pay frost to do some maf tuning for you. he got my setup spot on.
Old 04-19-2012, 07:37 AM
So new maf and frost tune?
Sounds good, been wanting a tune anyway.
Old 04-19-2012, 07:54 AM
SweetS10V8's Avatar
MAF Tune needs to be done in person. Buy HPTuners and do it yourself!! Its not terribly hard and after you do it a few times itll only take an hour at most.
Old 04-19-2012, 08:55 AM
thunderstruck507's Avatar
I have a stock working ls1 maf if you want it. I will sell cheap and can ship today if you PM me before noon central time.
Old 04-19-2012, 09:51 AM
Pm sent. Hope this will fix my problem.
Old 04-19-2012, 12:23 PM
the tune can also be done through email. i simply emailed frost the hptuners data logs and he sent me updates through email. after a few tries it was perfect.
Old 04-19-2012, 01:20 PM
Went in the mail, hope it helps you out.
Make sure the bellow and everything is clean so it doesn't get oil on the new one. Dawn or some other dishsoap should work for cleaning the plastic and not leaving residue.
Old 04-19-2012, 03:20 PM
Ok,I cleaned my lid, new air filter, and cleaned the air box.
Old 04-19-2012, 03:22 PM
I need to get ahold of someone with HP tuners
Old 04-21-2012, 09:14 PM
Fixed!!! Hell yeah!
Old 04-21-2012, 09:41 PM
thegroup's Avatar
now either find a dyno tune (best) or look up frost at tunedbyfrost.com. he did my 00 z28 and with it and switching to 4.10 gears, i went from 13.3 to 12.5 in the 1/4 mile. he is MO BAD with a tune.
mods on the 00 was suncoast ram air hood and box, stock maf, FAST 75 and stock TB, MSD 8.5 wire, SLP true LTs, superchips handheld, and texas speed and performance true duals before i had to replace my ring and pinion
Old 04-22-2012, 05:18 PM
14k
14k's Avatar
I love my frost tune. I think it's a little rich but I love it anyways.
Old 04-23-2012, 09:39 AM
Glad that helped you man!
Old 04-23-2012, 01:50 PM
Rating coming soon!
An thank you very much! Glad to see 12.5 AFR over 14.0 AFR anytime! Lol!
Should have seen my plugs!
