Flowmaster H Pipe U-Fit?!?
So I went thru the TD sticky and found these
The first pic is the over axels on both sides.
I would like to keep this under $500 for a h pipe. Now has any one used the flowmaster h pipe u-fit? Pictures? How did it fit? How was your clearance? How much work was it to get it to work? Is there enough pipe to throw it over the axels?
If not, What have you used
I'll probably dump before the axel for money reasons since I wanna be cheap but over axel would be nice.
Also can I run 3" all the way back? And will 3" fit over the axel?
I like the dual over axel on both sides (first picture) but I like the h pipe better (for sound purposes)
Has anyone used this h pipe kit?
http://m.summitracing.com/parts/sum-642030
if i were you i would save the extra money and go with the over the axle route, mines dumped before the axle and let me tell you ground clerance is a pain in the *** like now i cant even find a place to allign my car cause it wont get on their damn racks
summit x-pipe kit is good but doesnt really come with enough pipe. you will have to run to the store to buy a little extra. the flowmaster h-pipe u-build kit is great. you will have a lot left over. very easy to keep under $500 . just remember to buy all your clamps too
I might look into that h pile by flow master I know I posted one pic of the h pipe thanks
I found a flowmaster h pipe u-fit kit. Was that what you were talking about?
its just piping. you get to make the entire system yourself. lots of measuring twice cut once. It only fits as good as you make it. you can turn it into an x-pipe with just buying a universal "X" as well
