IAT cable and ??
IAT cable and ??
Can you guys tell me what wires I am looking at here? I know one is the IAT but which one and what is the other? Also, since I don't have the IAT hooked up my car is running extremely rich but I don't have the connector for it. So can I have the tuner tune out the IAT or do I need to get the piece for the intake and make a hole for it?
There is a fuel enrichment for different temps. Tuner would need to zero out the adjustment range on it and it should help the issue. Or the better solution get a working IAT sensor wired in. Purple 3 prong connector is TPS.
I will hook the temp sensor up since that should be a quick and easy fix. The TPS can easily be tuned out though correct? That I will not be able to run cause its not hooked up at all
So I'm still looking for some info on this. What is TPS? The connector that is said to be TPS has not been hooked up and I'm rewiring the motor so I'm curious as to where this is supposed to go? Thanks.
Bringing this post back because I still need to find out what that other plug is in the picture. Car has been running without it for two years but I'm doing a wire tuck and would like to know what to do with it.
