Over heating?
Brand new radiator and cap. Thinking my problem may be that the coolant hose coming out of throttle body is going into the overflow tank rather than feeding back into the radiator. Sound right?
lower port on radiator neck (below rad cap interface): steam vent crossover/TB.
upper port on radiator neck (right on rad cap interface): overflow reservoir.
So without having the port on the radiator for the steam tube where should I connect it? I was told to get a t-barb and run it off the overflow port and connect the overflow tank and steam tube to it. I believe this would leave me with the same problem though..right?
The radiator isn't a vehicle specific radiator. My ls is in a g35 so I went with a dual pass circle track radiator (this was suggested by someone with a 350z who did the same swap).
So any suggestions as to what to do with it from here?
