2004 silverado Fan Belt keeps falling off!
ill keep it short. truck is used for uphill sand climbs. 2004 silverado keeps dropping fanbelt at 6300rpm... any ideas.. or upgrades i should consider? its a manual trans if that help in any way..
I've always had issues with the stock tensioner and going over 6200....
get a manual tensioner... stock tensioner wasnt meant to handle the vibrations of high rpms...
also, if you have an underdrive pulley... it will amplify it and make it a lot worse than somebody with a stock pulley size.
Wrong...
The fuel limiter is much safer than a spark limiter...
Lean mixtures don't happen with a fuel cut off... its a zero mixture...which means no combustion and no pressure
Damage comes from a spark limiter... the fuel loads up and you get combustion at the wrong time...typically you get exhaust light off, which will blows up your exhaust pipes... it can also damage valves... and ocassionally you get the intake popped off.....
