1 7/8" Kooks install on 2002 Firebird
Im in the middle of installing my Kooks 1 7/8 headers and dual exhaust system. What is the best way to get the drivers side on because it is kicking my ***. The passenger side goes right up. I have the steering shaft off and the motor mount off but no luck. What is the best way?
Just keep playing with different angles and twisting it. If you have a friend helping you, have them look down through the hood area to guide you. I had the same issue. Take a break, don't get frustrated. It will slide right in when you get the angle right, and you'll be asking yourself how the hell that happened.
i just did my header install tonight.... hold on ill take some pictures of the part i got stuck on. and ill tell you how i got around it. very easy. took a video for you actually. what headers do you have?
Here's a video I took real quick for ya, show you where I got caught up at first.
http://www.youtube.com/watch?v=y9jxt...ature=youtu.be
Different headers but 17/8 still, had to take oil pan drain plug off and.oil filter then twist a certaib way for it to go in. Best thing to do new gaskets and bolts. Just my .02 cents
Hold the header up so the collector is vertical and the flange is closest to the fire wall (vertical) slide it up and be easy. At the same time you are sliding up you can rock the collector back towards the rear of the car to horizontal position. The less force you apply the easier it will just fall into place. Removing the oil filter may help a little.
UnRegard! Just noticed you got it in!
