Looking for a lightweight battery for a Daily Driver, Specs on OEM battery?
Don't know much about batteries but as far as reserve capacity what is needed to make the battery tolerable as a daily driver battery?
What is the specs for the stock OEM battery for our cars?
Was told to get a miata battery but not sure on the specs of that.
http://www.odysseybatteries.com/battery/pc925series.htm
This is what im worried about the Reserve capactiy look at the reserve capacity of the tomioka, from what ive read the reserve is what makes the battery more street able. Not the CCA. Maybe i have this wrong im no battery expert.
50 minute reserve capacity with 25amp load
Im not trying to take weight off a specific location, im trying to take weight off the car as a whole.
That wouldn't do me any good. Im trying to take away weight from the car as a whole, could careless where its coming from.
Thanks everyone who chimed in though, ill probably just look else were to shed weight for now till im 100% sure about a decision.
That's MISTER MODERATOR
The batteries that are being talked about in the Miata world are:
Battery/Cranking Amps
new (wet cell) Mazda/370
WestCo/475
American Eagle/530
The "new" wet cell Mazda battery is what they come with these days.
The Panasonic battery is no longer used and there seems to be no good info available about it anywhere,
I too would like to learn more about the Panasonic battery but they were from years ago and technology has marched on. If you have the coin, there are Lithium-Ion batteries on the market.
WestCo/475
American Eagle/530
Speed Inc carpet. Saves 40 pounds. Won't leave you stranded. Cost the same or less then a battery replacement, depending on the quality of battery you purchase.
Edit: Is it confirmed to really drop 40lbs? Did a small google search and alot of people are saying the stock carpet weighs 32lbs... The speed inc one is 19lbs uncut
WestCo/475
American Eagle/530
WestCo/475
American Eagle/530
Thanks again, i actually can't afford a lithium battery those are crazy expensive. I would have to ask 92cobranotch since he's the one who told me about that mod.
Thanks for clarifying!
So check this out he(92cobranotch) told me to just look under advanced autozones cheapest battery for a miata he said he thinks year 1999. I looked under 1995 and came up with this gem.
http://shop.advanceautoparts.com/web...000#fragment-2
Heres the specs! They look great and only $110. What do you guys think?
Battery Type: Lead Acid
BCI Group Size: U1RT
Cold Cranking Amps: 370 amps
Cranking Amps: 500 amps
Deep Cycle/Starting: Starting
Height: 7 3/16 in
Length: 8 1/4 in
Maintenance Free: Yes
Reserve Capacity: 45 min
Terminal Type: Top Terminal
Voltage: 12 v
Weight: 21 lbs
Width: 5 3/16 in
The autozone duralast version is as follows and the same price looks like the advanced version is 3lbs lighter.
Part Number: 8AMU1R
Weight: 24.0 lbs
Warranty: 8 YR
Notes: *** 370 cold cranking Amps (460 cranking Amps) *** 45 reserve minutes. -> 3 year free replacement <-. Check the customer's vehicle; battery installation could take up to 30 minutes. Battery located in trunk. Battery is vented to outside of vehicle.
Application: Automobile
BCI Cold Cranking Amps (CCA): 370
BCI Cold Cranking Amps Value: Tested to BCI Standard
BCI Designation: U1
Battery Height: 186 mm - 7 5/16 in
Battery Length: 197 mm - 7 3/4 in
Battery Width: 132 mm - 5 3/16 in
Core Charge Applicable: Yes
EN / DIN Designation: Not Applicable
JIS Designation: Not Applicable
Positive Terminal Side: Right
Post Location: Top Post
Reserve Capacity (min): 45
Voltage: 12
