ORY I-pipe muffler location
I'm going to install a magnaflow 14419 muffler in my I-pipe to reduce rasp. I currently have Kooks 1 7/8s with a Kooks ORY and Corsa catback.
Should I locate the magnaflow closer or farther away from the y-pipe?
Also, the Kooks Y exit reduces down to a 2.625 I.D for about a 3 inch length, should I cut this off to increase flow?
Thanks in advance..
Thanks in advance..
Come on exhaust guru's.
The muffler will fit perfectly over the 3" dia of the kooks Y. That's why I was asking about cutting off the reduced dia end of the Y to increase flow in this area. I do hate cutting up an expensive y that I may sell if I go to true duals someday.
A little bit of both. I loved the sound of stock with LM1 but I knew I was going to be modding it eventually.
I took away the drone (but some is still there,but not much obviously because its a bullet), and I actually wanted a "tone" to the exhaust. I love the way my Z28 sounds now. It quieted it down some, but defiantly sounds alot better. I have my 4 year old sitting in the back and the sound does not bug him one bit.
I do alot of highway driving in the spring/summer with the Z and I don't even up getting out of the camaro with a headache or anything. It's actually 'tolerable' sorta speaking, to the point where it does not annoy you.
Thanks in advance..
Thanks in advance..
Yes, cut off small diameter section!
The Scammer Hammer
Take a look in one of my old threads and see if the pics help you at all. My internet out here on the rig is SLOW, otherwise I'd post them myself.
https://ls1tech.com/forums/generatio...tall-pics.html
