Exhaust DIY?
Old 03-05-2013, 05:18 PM
Jack-DK's Avatar
Default Exhaust DIY?
Hi!
I am putting a LS1 engine from a Camaro in my Nissan 240sx.
I have some questions regarding the exhaust system on my LS1 swap.
- What size pipes would you recommend for the headers? I am going to fabricate it myself.
- How far away from exhaust ports would it be a good idea to assemble the 4 pipes to 1?
- Where would it be a good idea to assemble the 2 pipes, coming from both sides if the engine?
- What size of pipe is needed for the assembly of the 2 pipes going backwards?
- I am planning on, in the near future(maybe a year), adding a compressor. Does it make any difference in what size of pipes I should choose?
I hope these questions isn't to big of a mouthful! Any help is much appreciated!
Regards Jack
Old 03-05-2013, 10:14 PM
ur-n-8's Avatar
I made these to fit a thirdgen with 1 3/4" primaries and 3" collectors. As far as lengths you will probably have to go with what fits.
Attached Thumbnails Exhaust DIY?-camaro-part-2-141.jpg   Exhaust DIY?-camaro-part-2-140.jpg
Old 03-06-2013, 02:44 AM
Jack-DK's Avatar
Cool. 1 3/4 is it inner or outer diameter?
What about the rest of the exhaust? My plan was only one pipe going backward. 3" or 4" when the headers are collected?
Old 03-06-2013, 02:54 AM
Jadedbird's Avatar
go 1 7/8 inner diameter.. gives it a lower throatier bark
Old 03-06-2013, 05:42 AM
redbird555's Avatar
header tubes are measured in od. so getting 1-7/8 inner is like a 2" outter. just get a standard 1-7/8 od header tube. nice work op
Old 03-06-2013, 08:59 AM
Jack-DK's Avatar
Thanks. What about the wall thicknes of the tubes?
Old 03-06-2013, 02:42 PM
ckpitt55's Avatar
search for exhaust calculators - there are many available online that will help to determine proper primary size and length, collector size and length, merge points, etc based on what you're running. there's more to it than building what physically fits in the car, though that certainly is an important consideration.
Old 03-06-2013, 03:53 PM
Jadedbird's Avatar
Also i think SIkKy makes some quality swap items including headers
Old 03-06-2013, 06:17 PM
ur-n-8's Avatar
Wow, I can't even remember what I built. The pimaries are 1 7/8"
Old 03-06-2013, 09:07 PM
rathersmart's Avatar
what tranny are you running in the nissan?
Old 03-07-2013, 03:19 AM
Jack-DK's Avatar
T56:-)
Yes I know Sikky offers some headers, but my car is RHD and my engine mounts are home made, so don't thinks Sikky headers would fit:-(
But I'll try to find a calculator:-)
Old 03-07-2013, 10:21 AM
z28SSilvest's Avatar
I like this project OP. Continue updating us
Old 03-07-2013, 07:38 PM
ShevrolayZ28's Avatar
I think 16 guage (0.065"). I'm not sure.
Quick Reply: Exhaust DIY?
