Customizing CAI Fbody
so, ive been searching for a lid.. but the more i look at these engine bays, the more i realize... these damn lids are just cheap *** plastic that doesnt even fit right 9 times out of 10.
i was considering a FTP lid but again they even hit the hood...
so i was thinking myabe a clear mti lid.. cracks too often.. yada yada yada
volants are over priced and ive seen way to many bad posts about them
so the idea struck me...
why dont i clean it up a bit and just fab my own CAI
im not talking about chris1313...
like these: * i know these are FI but still...
basically, a few Spectra rubber couplers, some turbo piping and a Spectra cone style and ill be drawling the air from the hole under the turnsignal. my air pump was removed long ago so i figure it will have plenty of room
I think ill be running a 3.5" piping... maybe 3" ill be checking this weekend and fabing up the setup
im still searching for ideas on how to stabilize this set up. i figure i may just have to zip tie it or maybe rig some exhaust hanger(s)
also does anyone know of a cheap site to buy some turbo piping?
found some on ebay and autozone sells some but its about $20 a piece
I could just pony up the cash and buy the direct fit parts from Brutespeed but hey wheres the fun in that?!?!
here is a link to the radiator support i will be using
http://shop.brutespeed.com/ATI-MF006...MF006A-003.htm
it looks as if i will need to make it 3" to fit down into the wheel well and it may help with hood clearance anyhow
im hoping the 3" will fit without modification
i dont know hard it is to adjust the radiator, but ill letcha know
I need to figure out what i am going to do with that sensor that it in the lid. i suppose i could drill a whole in the aluminum piping and use the preexisting grommit
is there any certain guidelines as to the placement of this sensor?
oh and if this works..
I dub this the Jadedbird mod
Meh, thats really nothing new at all. You can stick any aftermarket lt1 cai on there and end up with what your trying to do. 3.5"-4" tubing would definitely net the same results as a lid. Thats what I have to do with my ls swap because a lid wont fit under the hood. With the filter in that hole you can cut a hole in the plastic and fab up something to catch and direct the air to the filter, in theory with out a wind tunnel lol. I have a link to some silicon cuplers and turbo piping but i doubt their a sponser.
just curious what your reasoning for doing something like that is...? i think a lid looks much cleaner and offers the same if not more performance capability than one of those goofy looking cai induction setups.
good luck with whatever you do. fwiw i bought a whisper lid 7 years ago and i've had 0 problems out of it.
Well like i said, the lids in my opinion are junk. Ive went thru several lids and found each lacking in fitment. I dont see how i can loose that much hp. (Maybe 1 or 2 at the most) the cone style filter is a better performing filter compared to our nice little POS filter.
My dad also told me to consider relocating the battery and putting the filter in that location.
I will be going through several options and ideas
It's not mine! woo hoo!
My SLP lid fits perfect now that I switched to an Airaid filter. Not sure what it is about it, but I always had issues with K&N and paper filters.
While I don't really see anything "wrong" with your idea, I'm thinking it may be extra "work" for something that may not be better. I understand why you're considering it, though.
Ive seen back to back dynos with a lid and a lt1 style cai. A lot of lt1 guys wanted to switch to a lid. The gain from the lt1 style cai to lid was about 1-2 horsepower. Fwiw, according to my local lsx shop the loss is from the 3" or so piping. If you can fit a 4" tube for the whole intake there is virtually no difference.
why not go over the radiator with a 90* bend and drop the filter down in the front like a few guys on here have done. i was thinking about doing it myself for a whiile, just dunno if its worth it. it looks a hell of a lot better then a lid and the setup your trying to run, its one coupler from tb to pipe, a 90* bend down to a filer. you have to notch the top of the radiator a little bit to allow the pipe to sit on and run down
If i could find a quality lid then i wouldnt bother with it, but its not all about numbers for me. My t/a is more of a show and play than a competative type.
Sure ill lose that .2 on the 1/4 mile and that 2-5hp. But my konis/stranos are gonna make me lose another .5. and besides my ls2 will be pressing 450 easy.
Also i am not much of a fan of the straight on 90s. They are alright but in my option (and this is strickly a matter of what appeals to you) i like they "lt1" style elbow intakes.
And i know this isnt new and that most run these on lt1s but ive never seen a ls1 running the style of CAI like what im planning. I have seen the straight on 90 bend like me tio ed earlier.
