Exhaust with spohn tunnel mount T/a?? True dual probs
I bought a spohn tunnel mount torque arm and my texas speed true duals are not even close to clearing the crossmember. It looks like i may have to go with a single set up through the crossmember. What have you guys done??
Btw this is a heads cam nitrous car with a th350. I'm thinking custom 3" to flowmaster merge then 3" pipe to a single bullet? Opinions?
Thanks -Josh
Thanks -Josh
if you go with a tsp y-pipe, cut off the choke point (2.75") and you'll have a full 3" y into a 3.5 merge....then run a 3.5 borla #40086 or some other 3.5 glasspack muffler dumped before the axle (Summit sells one for $78)....it should be fairly inexpensive, clear everything, sound mean, and flow very well.
i'm interested in the duals.....what mufflers?.....what are you looking to get for them?.....PM me a price to 37153
I have decided to go with the tsp Y to 3-1/2" pipe to a single bullet for a few reasons. It's cheap, simple, more ground clearance, and won't be as time consuming. I loved my duals but we'll see how this project turns out. I'll post the results when i finish
-Josh
If you don't have any useful information/suggestions that someone would like to hear, go be a jackass somewhere else. Thanks for your negativity --Josh
