Need some advice
Old 04-09-2013, 06:12 PM
cbr600rx7's Avatar
Default Need some advice
Running a 05 crew cab Z71 with duel exhaust and a Eaton M112 magna. The truck is running a 3.4 upper and making roughly 8 pounds of boost at WOT. I did have the truck on a mustang dyno a few months ago and it made good numbers at 370whp and 402tq. This is a stock cam/head 5.3 iron block 4L65 set up and the AFR’s and tune are on the safe side. I have been considering going to long tube headers since I have a small exhaust leak any way but don’t want to spend the money on a tune until I have the time and money to do a few other mods.
What do you guys think.
Old 04-09-2013, 11:04 PM
conan's Avatar
I think Texas speed has a long tube and Y pipe set up for the trucks, it was pricy when I looked into it due to the 4wd.
Exhaust would wake it up for sure, I would also open up the intake side of the Eaton as well... TB, MAF (if you run one) and the biggest air filter you can fit.
Old 04-10-2013, 04:26 AM
cbr600rx7's Avatar
I am running a AFE stage 1 intake with pro guard filter on the intake side with the magna intake pipe. The truck has true duel exhaust on it right now so all I would be changing would be the manifolds and going with the armor coated pacesetters going off what trucks guys have told me.
Old 04-10-2013, 08:49 AM
Blackpanther99's Avatar
You can always buy a steinless Y-Pipe off of Ebay, but your better off with True Duals. Specially if you pick up some more power.
Old 04-10-2013, 08:03 PM
cbr600rx7's Avatar
My main concern was the location of the 02 sensors. With them sitting much lower away from the heads I didn't know if it would create a lean condition.
Quick Reply: Need some advice
