Cruise Control Not workin??
Originally Posted by 2000Z28M6
Just finished doin the drill and bump stop mod, now my cruise control doesnt work. Visually inspected for any loose prongs or sensors all looks ok. Any ideas where or what I should look for?
Thats what im talkin bout, Thanks for the advice. 14u2nv I'll try it tomorrow, my back is soar from being twisted for bout 3 hrs yesterday. I was thinking the same thing but I had no idea where to look. This is why I love this board. I'll let ya know if that solved the problem.
Thanks for the advice, worked and your rite it has to be completly depressed. Otherwise it doesnt work, I tried halfway but nothing until i adjusted all the way it went, then it worked. Turning was a little difficult due to the wire harness on the switch, I didnt want to undo it first to much trouble so I just carefully managed.
As soon as I read this, "Just finished doin the drill and bump stop mod, now my cruise control doesnt work" I knew it had to be the switch. I chased this very same problem down for days. I got my SS back from Rapid Motorsports after having the ARe H/C, Moser 12 BOLT and RAM clutch done and had the car for about 3 days then the cruise stop working. I posted several times without getting any replies so I kept looking around. I ended up replacing the other switch(the other in front of the clutch lever)and that didn't help at all. I didn't even see the "cruise" switch at first. I was just about to give up and take my SS back to SATAN (the dealer) and I figured I give it another try. Like I said I just got the car back from Rapid Motorsports, having just spent almost $14,000.00 I was PISSED to say the very least. I email Mikey and I got no response, that added to my ANGER. If he wasn't 7 hours-13 minutes-17 seconds and 402.83 miles away I was about to take the car right back...that was how pissed I was. Finally Mikey called me back an asked me about the other switch; that was it! So I will always remember that damn switch.
My cruise control doesn't work either & I trouble shot quite a bit of the circuit & couldn't find anything wrong. I'll definately check this switch out that you've mentioned, hopefully it's my problem as well, Fred
STF Veteran
Congrat on your fix. Keep in mind fellas that if one of the bulbs in the high mount stop light goes out, that can effect the brake circuit which is monitored by the cruise control computer. It causes the circuit values to change and often times the cruise will not engage.
This is a common problem with that switch. It is more common after doing clutch work but it can get out of adjustment with age and use. I fix this problem on the C6500 series trucks all the time.
