View Poll Results: Would you proceed with engine installation?
Yes
2
20.00%
No
8
80.00%
Voters: 10. You may not vote on this poll
[PICS] Oil Pan Crooked Relative to K Member. Problem?
I just installed my engine. I got under the car and noticed that the oil pan is crooked relative to the k member. Is this a problem or would you proceed with the installation of the engine? Thanks
Also, is there a torque value for the fasteners that connect the engine mount pedestals to the kmember? Thanks
Only thing I can think of is something is flipped around whether its the pedestals or the clam shells. The metal ears on the polys that stick out should be on the top when the clam shells are installed on the engine. The problem is those ears catch the pedestals so then u can adjust from there to get the bolts through. When u look at the pedestals there will be a notch out on the top side. So whether you got the bolts through or not using the various methods on here those ears being on the bottom side and not sitting in the notch out could be screwing u
What have you recently changed on the car? I mean obviously the engine didn't come like that from Chevrolet, so what all has been done to it? Trying to track down the source of the mis-alignment.
I dont believe it is the block unless I got two tweaked blocks as my last engine sat like this as well. Now correct me if I am wrong, but it seems to me that the misalignment could only be because the:
-frame is tweaked
-k member is tweaked (i think this is the problem as this car had sportlines on it and that kmember is pretty beat up)
-pedestals are tweaked
-poly motor mounts are tweaked
obviously, the frame is the same. the kmember is the same but i have another that i will be installing this weekend to see if anything changes. i swapped the pedestals out with other units that i have and will put the "new" pedestals on the "new" kmember when i reinstall it, obviously. i will open up the poly motor mounts to make sure everything is as it should be.
does anyone have any pictures of exactly what the passenger & Driver side motor mounts should look like so i can determine if mine are correct or not? thanks
Hate to be Captain Obvious but the trans plays a big role in the direction the engine points. (tail mount being centered in the tunnel) I would get it back in before jumping to conclusions.
could you go into more detail as to what exactly you are saying please? I think we are on the same page but I want to make sure. are you recommending that i hook up the bellhousing and transmission and reassess my situation at that time? and just to be extra clear, the engine is not sitting level in the kmember. it is higher on the passenger side. i have no idea if the crank snout is pointing more towards the driver or passenger side, how one would determine that?
Yes, the engine may not sit square until the trans, trans mount, trans cross member, are all installed and tightened down. The trans being straight in the tunnel, and attached, ensures the motor is square in the frame rails.
i had a chance to redo the factory clam shells. the temp dropped before I had a chance to do anything with the kmember.
i did find that one of the ears on one of the poly motor mounts was bent so i straightened that back out.
are the poly motor mounts side specific?
are the clam shells side specific?
I just installed my motor/ k-member in my car today and I'm having this EXACT same problem. I have prothane poly inserts in stock clamshells and LTs on an LQ4/t56 in a 97 f-body. The whole motor is rolled towards the drivers side almost exactly the same way the OPs is. Mine was a little different tho bc the it was an absolute PITA to get my motor mount bolts lined up when dropping the motor in the k-member. And you can bolt the motor mounts on the motor both ways bc I tried it both ways to see if it would help when bolting the motor to the k-member...was off just the same both ways. Never been so frustrated in my life as I was trying to get that motor bolted in lol. I have the wrong trans mount in it right now so the trans is crammed up in the tunnel too far. Hopefully when I get the trans lowered down where its supposed to be it might fix the alignment problem...
