High-Flow Cats-Worth it??
Old 03-26-2014, 02:08 PM
JWGchevy's Avatar
Default High-Flow Cats-Worth it??
Is it a myth that high flow cats are worth it or are they just a waste of money. Wanted to get y'all's opinion.
Old 03-26-2014, 02:18 PM
Darkman's Avatar
It probably depends on the car, since different years start with different factory cats. On my 2005 CTS-V (LS6) I picked up 25 HP with 2 modifications one being high flow (Random Tech Cats) and the other being a lightweight flywheel. I believe at least 15HP can be attributed to the high flow cats. (Since I did not dyno with each of the two changes however, I cannot prove it.)
Old 03-26-2014, 03:07 PM
DANOZ28's Avatar
darkman you must have had some really restricted cats WOW! on our ls1's i would guess removing the cats would save you upto 8 rwhp & switching to high flow should get you halfway there. so maybe 4 rwhp. just my one cent opinion.
Old 03-26-2014, 03:47 PM
Darkman's Avatar
Another factor may be the difference in catback systems. The CTS-V has a high-flow cat back consisting of a resonator that is actually an X-pipe and low restriction mufflers connected with a true-dual 2.5 inch stainless steel system. So, on the CTS-V, once the factory cats are gone you are accessing a pretty good catback. I don't know how restrictive the LS1 cat backs are.
Old 03-28-2014, 10:26 AM
MikeWS6's Avatar
They are too expensive and dont last long. Run no cats.
Old 03-28-2014, 10:54 AM
WS6ICK2k's Avatar
+1 Doesn't flow better than running without them.
Old 03-28-2014, 01:11 PM
Justhereforinfo's Avatar
But it sounds like ****. Id rather sacrifice the 4whp personally than listen to that raspy crap
Old 03-28-2014, 01:20 PM
Rise of the Phoenix's Avatar
I don't think the cats are what takes away the raspy sound. I've got true duals without cats and it's not raspy at all.
Old 03-28-2014, 03:13 PM
joecar's Avatar
Cats are for appeasing The Authorities... high flow cats can't get an EQ#... so The Authorities disapprove... so high flow cats do not help you, leave them off, you're no more illegal than with them on.
(not to mention your budget)
Old 03-28-2014, 03:19 PM
If you're needing them for inspection reasons, just hollow them out. Visually, they will be there, but nothing more than an open pipe.
Old 03-28-2014, 05:34 PM
LPE 403's Avatar
OP - not sure what you're you dealing with cube or power wise, but I gained a few gutting mine. Kooks duals....
Old 03-28-2014, 06:17 PM
Goosecaddy05's Avatar
it depends on your mufflers... some will sound absolutely terrible when you remove the cats... i hate raspy tingy mufflers also... they make your car sound like a cheap barn door pos.... i recently removed the cats from my system and it just got a little louder... still has the same deep thunderous tone as before ... cant beat b&B exhaust for sound quality
Quick Reply: High-Flow Cats-Worth it??
