Do you put anything on the header bolts before installing them?
Old 05-16-2004, 11:26 AM
9 Second Club NA
Dragaholic's Avatar
Default Do you put anything on the header bolts before installing them?
I was just curious because I removed my longtubes yesterday and the bolts were a little difficult to get out. I had to use the ratchet almost all the way until they came out before I could start spinning it with my fingers. I used Fel-Pro C5-A anti-sieze lubricant. Was that a no no? Just wondering if I was or wasnt suppose to use that and if not, what do you put on them if anything? Thanks.
Old 05-16-2004, 11:29 AM
RAMnGO's Avatar
I didn't use anything on my bolts when i put them in. Later on i used a bigger wrench size bolt and still didn't use anything on them and even after 8 months none have come loose.
Old 05-16-2004, 12:06 PM
ACCELR8's Avatar
If I remember correctly I used anit-seize
Old 05-16-2004, 12:07 PM
DARK AGE 53's Avatar
Using an anti-seize is wise, you did good.
Al
Old 05-16-2004, 08:48 PM
S2002S's Avatar
The shop manual says to use locktite. I followed the manual...
Old 05-16-2004, 08:56 PM
ddelallata's Avatar
the manual says Loc tite after the 3 thread
Old 05-16-2004, 09:01 PM
14u2nv's Avatar
I have never had any issues with my header bolts loosening at all and I am using the stock bolts. I haven't used any loctite or anti-seize.
Old 05-17-2004, 12:20 AM
SapphireHawk's Avatar
I also used anti-seize. I put it on my Stage 8 bolts before I installed them.
Should make my Head / Cam install easier, whenever that will be.
Old 05-17-2004, 10:20 AM
hourang's Avatar
anti-seize
Old 05-17-2004, 12:29 PM
Kevin 276's Avatar
Yes, you should use anti-seize on aluminum heads, good choice.
Old 05-17-2004, 12:52 PM
NOBR8KSS's Avatar
Iron threads and aluminum heads = anti-sieze
Quick Reply: Do you put anything on the header bolts before installing them?
