Bought another motor. What do I need to make the swap???
Well I bought another motor out of a 99 Camaro(heads cam) and I need to know what I can reuse from my 98. I bought the long block minus waterpump, pulleys, timing cover, and intake. I am going to swap over all my accessories and oil pan, timing cover. I have a LSX intake for the motor but I believe I need to buy coolant lines, and or plugs to swap from an ls1? I think I need a crank seal and crank bolt too? Do I need new gaskets/seals for timing cover and oil pan and waterpump? Also I have 93k miles on the old motor, can I go ahead and reuse the header gaskets? Is there anything else I need or am forgeting? I want to have everything I need ready for the motor swap.
Thanks,
Jesse
Thanks,
Jesse
Yes, you'll need the coolant cross over pipe and the rear coolant plugs.
Thunder Racing has the crank seal and crank bolt, as well as the timing cover, waterpump and oil pan gaskets.
The header gaskets can most likely be re-used.
You'll need to swap your coolant sensor from your 98 motor to the new motor.
So what all do I need off this page? Do I need a rear seal and rear cover gasket??Is the front seal the crank seal??
http://www.thunderracing.com/catalog...vid=3&pcid=227
20-12558760
20-12585673
20-12585671
20-12574293
I don't think so, but here are the part #s you'll need, also, don't forget the crank pulley bolt.
Part #s for coolant tubes and plugs:
1x 2001+ front coolant pipe - #12568478
2x 2001+ rear coolant plugs - #12562788
Also, since the motor is out of the car, go ahead and do the LS6 PCV Valley swap, all part #s and install is here:
http://ls1howto.com/index.php?article=18
