92 mm FAST INTAKE ISSUE
I feel dumb for asking, I installed the FAST intake and Nick Williams TB yesterday and I didn't see a port for the HVAC system like on the stock manifold. Did I over look something is their another way to get vacuum so my blend door will work correctly? Thanks
The small vacuum port is on the passenger side, directly behind the very rear manifold mount bolt hole location(see photo above) Get you a rubber 90* vacuum port/line connector and first install it on the hard vacuum line, then install it on the side port on your FAST 92 manifold.
