Cylinder head id
Old 07-10-2014, 12:54 AM
occhevelle's Avatar
Default Cylinder head id
I have a pullout LS1 from a 04 GTO (so I was told). I checked the heads and either I'm having a moment or the casting numbers are ground off. Is this normal or am I looking in the wrong place? Can I id them from the longer number below?
Old 07-10-2014, 08:15 PM
poltergeist 02's Avatar
Do you have pics of the exhaust ports?
Old 07-10-2014, 08:52 PM
occhevelle's Avatar
I would have to pull my headers off. Engine is in the car
Old 07-11-2014, 06:10 AM
Do you remember if they had D shaped ports?
Old 07-11-2014, 07:15 AM
JRENIGAR's Avatar
Casting # should also be in the rocker valley.
Old 07-11-2014, 10:32 AM
occhevelle's Avatar
I found a pic from when I was installing the engine and the exhaust ports are round
Old 07-11-2014, 06:17 PM
I'm going to guess they are 241's then. I'm not sure why they would go through the trouble to do that if they are 241's though.
Old 07-12-2014, 12:59 AM
occhevelle's Avatar
That's what I thought. I can't think of a good reason to shave the numbers off other than to hide switching in heads that were worse than 241s
Old 07-12-2014, 08:42 AM
occhevelle's Avatar
Or maybe an indication somebody did some work to the stockers but it sounds like there's no easy way to figure that out. I'll think that way to make myself happy. Thanks for the replies.
Old 07-12-2014, 05:50 PM
For the sake of finding a good deal, I hope your right!
Quick Reply: Cylinder head id
