what ground is this??
Old 08-10-2014, 11:40 AM
Gotit4cheap16's Avatar
Default what ground is this??
I was putting my engine and car back together and seen this cut ground....I have always seen the wire before and cut but never really knew where it cam from u til bow....should I be worried and re ground?? Or should I not worry about it??
Old 08-10-2014, 01:04 PM
WS6wanted's Avatar
Where is that ground located, hard to tell from the pictures
Old 08-11-2014, 08:14 AM
It's located on the side wall near the druver side fan below the fuse boxes and attaches to the bottom driver side of the motor
Old 08-13-2014, 12:32 AM
Bump. ...
Old 08-13-2014, 01:10 PM
That's MISTER MODERATOR
Paul Bell's Avatar
It's one of several needed grounds. Replace it with new.
Old 08-13-2014, 04:03 PM
nancygrl's Avatar
In my 2002 ws6 I looked in my engine bay and traced the braided cable going towards the alternator bracket area where I can't see where it goes after that. Hope it helps.
Old 08-13-2014, 06:17 PM
Where can I buy it new from or should I make my own?
Old 08-13-2014, 10:01 PM
99Bluz28's Avatar
Get a Taylor Braided Ground Straps #148014, it's a lot beefier, and less expensive than a stock replacement!
http://www.summitracing.com/parts/tay-148014
FYI. Taylor also offers a 8", and 18". The 8" is to short for that location, and the 18" is really longer than you'll need.
Here's the block mount location behind the alternator:
http://www.fl1v.org/ls1/g111.gif
Old 08-17-2014, 11:36 AM
Thank you
Old 08-17-2014, 01:07 PM
99Bluz28's Avatar
Your welcome.
I'm just glad to be able to help.
Quick Reply: what ground is this??
