LT1 radiator for LS
Old 09-14-2014, 04:39 PM
BOLO's Avatar
Default LT1 radiator for LS
I'm in the process of swapping in an LS into my 94 Z28. Can I still utilize my LT1 radiator for the LS motor? Can I use the same upper and lower hoses, or do I need to get hoses made for the LS? Thanks in advance.
Old 09-14-2014, 08:31 PM
Moderator
jimmyblue's Avatar
Nope, hoses are fine, just have to plug or cap the couple
of unused heater hose ports (?) on the LT1 tanks. Other
than that, fits right in and cools better.
Old 09-15-2014, 08:17 PM
BOLO's Avatar
Thanks. Are the LT1 oem radiator better than the ones for LS1 oem?
Any other suggestions are greatly appreciated, thank you.
Old 09-15-2014, 08:25 PM
ramairetransam's Avatar
yeah they are thicker
Old 09-16-2014, 10:38 PM
Macs98Z's Avatar
If I remember correctly, I have noticed probably a consistent 20* difference in temps from swapping to an LT1 rad. It made a big difference.
Old 09-18-2014, 07:39 AM
01ssreda4's Avatar
EBay sells aluminum radiators for 150 for fbodies. No reason to reuse old stock junk.
Old 09-18-2014, 08:17 AM
BOLO's Avatar
Ok., Thanks, I will look into it.
Quick Reply: LT1 radiator for LS
